The car is R33 GTST RB25DET Series 2. Stock. She was sitting outside for 4 months all winter.
She will crank but won't start. Here is what I've done/checked so far:
1. All ECU inputs and grounds checked - ECU checked for inputs at the connector only (maybe ECU is fried?)
2. Ignition - coils fire, harness rings true, connectors all ring true.
3. Changed spark plugs, tried different gaps, I have spark for sure.
4. Drained fuel, flushed with fresh fuel. Injectors fire, all of them.
5. CAS - works mechanically and electrically.
6. Timing belt proper tension, no slipping
7. Temp sensor works and gets signal
8. ECCS relays work and ring true
9. All the fuses ring true.
10. Battery is good.
What the hell am I missing? Bitch won't start!!! Please help!
Edited by Skyride
https://www.sau.com.au/forums/topic/441548-r33-gtst-wont-start/
can you hear the fuel pump wine up when you turn the ignition on before you try to start it?
Yep. Primes for 4 sec. It gets fuel all the way to cylinders because when I changed plugs, it was wet with fuel and I could see dropplets on the pistons. Also, when I flushed fuel, I did it with fuel pump through fuel lines just to be sure the pump works.
Edited by Skyride
do you have a consult cable and software or do you know how to bridge the pins and read the flashing dash light to check your ecu and for any sensor errors
No. I am clueless as far as bridging the pins goes. And I don't have consult either. I should probably get one. Is there a manual for bridging the pins? I have a R33 service manual but all the ECU diagnostics there are based on Consult. All I did is checked inputs to ground with meter and corresponding device if it works. But of course cannot tell if ECU fires correct outputs...
ok the procedure is on this page, you will see the pics of the plug under your steering wheel near the fuse panel, and it shows you which pins to bridge, you just need a paperclip or hairpin, what you do is turn your ignition on and bridge the pins for about 10secs and then remove it and the orange check engine light will flash a code
  • Like 1
How did you confirm the injectors were working? Did you take them out? If so, what did the spray pattern look like? Maybe they are dirty and leaking, thus flooding the engine.
Maybe try starting with WOT. But in the long run you may need to remove and clean the injectors.
  • Like 1
I confirmed by meter before, today I took them out. They work. Tried WOT start - still nothing.
Tried some Aerostart of Startyabastard?
Tried that too.
And here is another surprise. Tried the procedure with bridging pins. Guess what?!?! 55!.... I am really lost at this point :(
How do you check an injector works with a meter? Just 12v supply or are you using a multimeter with duty cycle or oscilloscope to check?
How have you checked the coils? Have you seen a spark from them?
If it won't start with aerostart you have no spark.
Check coils are actually sparking
Edited by superben
wow you have tried all the main things and more, do you have an alarm fitted to it or any piggy back computers hooked upto your ecu
Was thinking the same thing re alarm. No, it is not wired to cut ignition or starter. Just doors. Bypasses all the vitals (which is not a good thing, lol. I will rewire it later to cut the ignition). Just took the ECU apart because previous owner told me that it has flashed chip. Nope. Everything factory and no piggy backs. Got hold of stock RB26dett ECU. I know it's based on two mafs and itbs but other than that pin layout pretty much the same. So, basically want to try to plug in for start up only just to rule out that my ECU is fried. Hopefully this will help...
I tried to check for power and coil resistance first without taking them off. Today I actually pulled the whole damn thing apart and tried to start with injectors sitting on the blanket to see the pattern and if they all spit. They all have nice pattern and spit nice spray consistently.
Coils...yeah...where I begin haha. I am kinda pro as far as coils go. I tried three different sets - my LS swap (thought first may be I screwed up with harness wiring), splitfires and oem. ALL of them shoot spark. The LS spark is so strong I was firing it with fire extinguisher ready lol. So, no, coils are good FOR SURE.
Aero start. I took manifold off and sprayed the stuff straight in there. It shot very exsiting flames. But NO FREAKING START!!!
Well, at this point I think that the only thing is something is out of order as far as firing sequence goes. Which brings me to believe that I do have faulty ECU. I will try tomorrow with RB26 ecu and if this damn thing starts, I am going to either buy new stock ECU or possibly to just go all out and get me a Haltech...
Wish me luck :)
Oh. and just to add. I swapped another CAS. Didn't help.
Edited by Skyride
Was there any particular reason the car was sitting outside for 4 months?
There's one part of the picture that hasn't been covered - do you have compression? (And I mean checked with a compression gun)
For the CAS, is the half-moon key still in the end of the exhaust cam? If it's gone, then if the CAS isn't installed in the right orientation, there is very little chance of the engine starting.
  • Like 1
i know i would be more than happy to do that but im in ballarat which in guessing isnt anywhere near where you are lol, and since i have exactly the same car as you i think we should compare stuff like fuel pump voltages when cranking and stuff like that, cos just cos you have power at certain points it doesnt mean its the right amount of power
  • Like 1
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
