Located: Central Coast Gosford
Postage: Willing at Buyers Expense
Prices: Some negotiable
Pictures: available via text
Contact: Leon, 0404921287
R34 Injectors 340cc Top Feed $150
R34 GTT Coilpacks $150
R34 Standard Camber Arms $20
R34 Standard Triple Gauges $60
CA18 Standard Turbo Manifold $50
2x R33 GTR Turbos in Pieces $50
CA18 Fan Should Upper/Lower $30
CA18 Clutch Fan $50
CA18DET Engine All Bolt Ons $250
CA18DET Loom Excluding 2 plugs $30
HICAS Rack from 89 180sx $30
RB25DET S1 Engine All Bolt Ons no turbo (in pieces) $600
RB25DET S1 Loom $50
RB25 Forward Facing Plenum Standard Throttle Body $250
Unknown Side Mount $10
RB Engine mount adapters to Holden HK $40
Ford Falcon AU Thermo Fans $25
180sx Genuine Plastic CA Front Bar $150
180sx Genuine Plastic CA Rear Bar $50
180sx Genuine Plastic CA Sideskirts $250
S chassis Double Gauge Pillar Mount 52mm $50
Xtrons TD717 Double Din Headunit $50
Kicker ZX200.2 $125
S14 S2 Fuel Pump $40
https://www.sau.com.au/forums/topic/441571-r-s-chassis-clearance/
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
