I am about to do twin EGTs and twin Lambdas in to my R34 GTR and want to know what people are using and where you have placed them
My ECU will take any 5 wire O2 sensor so long as I can get the values for it otherwise it is preprogrammed for the NTK LZA-09-E1s, which I plan on putting at the start of the front pipes before the CATs
My ECU has twin K type thermocouple inputs for EGTs and they recommend 1.5-3mm hi inconel SS probe, which I plan on putting into the hole where the factory O2 sensors go
Any ideas or comments or suggestions, feel free to add any ideas you guys have
https://www.sau.com.au/forums/topic/441930-egts-and-o2-sensors/
I maintain that EGT measurement AFTER the turbo is a waste of time. There is a significant energy loss across the turbine. It is preferableto measure upstream the turbo. So, either in the manifold collector, or perhaps drilled into the turbine housing just after the flange.
I have my EGT sensor install exactly there (in the turbine housing). Has been there for 2 years now. Doesn't leak, hasn't caused any grief. Still reads the same sorts of temperatures at the same sorts of loads as it did when first installed, so clearly it is able to survive there. is good.
I'd say a 3mm inconel sheathed Type K theremocouple. Set up the fitting to insert the tip just a few mm into the gas stream. Job done. It does tend to measure the temperature of the housing itself a bit once the housing has been heated up by the gas on a heavy run, but it certainly reacts fast enough to gas temperature rising when the load increases.
Mine is just a cheapy Taiwanese ProSport EGT guage. You know those stepper motor Defi clones. Came with thermcouple and fittings. I just drilled and tapped a hole into the turbo while it was off the car. That's the big hassle with fitting upstream the turbo - it's hard to impossible to do it on the car. Iand probably not a good idea to try either).
I'm only looking at the factory location due to room and hassle of fitting, the factory O2 location is easy enough to get ATM, ideally the collector area in the manifold would be ideal and definitely something I will be looking at when the motor comes out next time, and given it a running GTR its only a matter of time now :D
I removed both my o2 sensors and used a stainless adapter to run 1/8npt egt on dump pipes where the 02sensors used to be. One thing i overlooked at the time was using different metals, cast iron/brass/stainless all expand at different rates and although i haven't noticed it on my car a lot of people have problems with their threads loosening over time.
I also fitted a wideband sensor just before the cat. i wouldn't run the sensor too close to the turbo they aren't really made to be permanently mounted. a lot of people have damaged their sensors prematurely mounting off the dump possibly because of the extra heat.
  • 4 weeks later...
Stumbled across this a few mins ago
expensive, but saves buying 11ty guages, will read everything from boost to exhaust manifold pressure, fuel pressure and temp, IAT's etc
http://www.zada-tech.com/product/multi-gauges/43-full-colour-tft-lcd-multi-gauge
A few sensors ive seen are quite long, if i mount one jn the exhaust housing of turbo, how long does it need to be?
And if i get industrial thermocouples Australia to make some up for me what length do i tell them?
If i lower my intake temp through ceramic coating and insulators on intake plenum, fmic and piping will it make a noticeable dif to temp in exhaust housing?
You only want the tip of the TC to stick in a few mm. In a big pipe like a dump it could go in 12-15mm and give a faster response to exhaust temperature changes without interrupting flow too much. But in the manifold collector or turbine inlet you only want the end of it peeking through.
My TC is bent. The insertable bit is only 30mm long or so, and it has the stainless olive/gland on it to screw down onto the stainless fitting tapped into the exhaust housing. If you get yours bent then a 50mm length on the last straight bit will enable you to insert it anything from just barely to more than enough, I should think.
Keeping the inlet temperatures cooler by, what, 30°C, isn't really going to have a noticeable effect on the exhaust temperatures. You might see a small decrease in temp (although be hard pressed to notice it) but given that the end effect of cooling the intake charge down is usually to put in more fuel and air and hence make more power, you might not expect to see much!
That is a good thing, just doesn't give the ECU inputs for safety protocols for engine cuts
This is what I'm going to get for my Syvecs soon
http://mobile.dudamobile.com/site/jti-site?url=http%3A%2F%2Fwww.jti.uk.com%2Ftoucan%2F&dm_redirected=true#2902
Speaks for it self really, its just really expensive but all inputs come from one of the CANBUS outputs from the ECU
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
