Not a huge week on the car.
Swung past the paint shop to take some photos.
Cars so white its hard to see the lines.
Very bright, very happy.
Got some 18x10 panasports and thinking about selling my old ones.
20170526_123129.thumb.jpg.1779a230e4ee54a48b06df96c2457d82.jpg20170526_191521.thumb.jpg.7bc7f97b6664bc8fa9e1ed40a8d04858.jpg
Test fit shows they sit perfectly but need some decent tyres on them.
Currently 245/45/18 thinking 265/35/18
These will be pulled apart to have the centers painted Ferrari grey charcoal.
  • Like 3
  • 3 weeks later...
So no really big updates with the car at the moment however the workshop has been receiving some much needed love.
Floor after degrease and steam clean20170610_011350.thumb.jpg.b1a13971b79959d7443e35ab2e1a909b.jpg
And after paint.20170611_162318.thumb.jpg.a99704a488351917a24e5dfcb5fbe313.jpg20170613_173525.thumb.jpg.4db6821fa3aa674627e274f038114676.jpg
Looks alot better now to do the other 300m2
The office also finally got the outside painted20170617_135559.thumb.jpg.2d31d5477eea7af2bd30d216fce71361.jpg
Just little steps that make the difference.
  • Like 2
Went over to the paint shop today to pick up the bare shell, time to get it on the hoist and start stripping thr rear subframe and coat the under side.
Also picked up a set of high vis rb26 covers that we had painted for a customers car20170622_103759.thumb.jpg.9b80bf8a5b2c53133fe9bcfee0f11e0a.jpg
Got the other hoist up in time hide the 32 away till i finish reorganizeing the workshop.
Once thats doneqq i have to paint the rest of thr floor
  • Like 1
Slowly putting bits and bobs back into the engine bay. Not going to crazy as i know i still have to prep the underside for under body coating20170704_122302.thumb.jpg.11d05d8d44813ea976115f73a05b7ef8.jpg
New headlight rubbers and clips
New top and bottom bolts for the bonnet support bracket.
Everything that can be replaced with new will be on this car, if i can't get it new it will be restored as close to factory as possible.
Finished this gtr off the other day has a few nice bits and makes good power now.20170703_095211.thumb.jpg.7424da0c3b42063d07b0651c5fbdac92.jpg
As i get older the enjoyment of a quiet well handleing ride brings me enjoyment.
The whole car is going to be convered in a layer of dynamat on the roof and doors therr will also be a layer of dynaliner on top of that to keep the heat down.20170705_190227.thumb.jpg.5832c1352ee4df3ff92e13e8760e6966.jpg
20170705_190236.thumb.jpg.673a5c08af852ebd76da5a7e6e31eb6d.jpg20170705_190251.thumb.jpg.a4c65da15a51febfa810f5ff3f4ea36c.jpg
  • Like 2
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
