Here i have for sale my pride and joy which i have owned for the last 5 years, This R32 would be perfect for anyone after that quick street able GTR they have always wanted. The car is currently making 310kw ATW on 98 pump fuel at 20 psi on a conservative tune for reliability ,with a E85 Tune the car made 375kw on 20 psi. With more boost and E85 this car will push over 400kw easy . Selling it due to having a work vehicle now and not much opportunity to drive the GTR anymore.
Below is a list of the major modifications on the car
R34 GTR N1 Engine Rebuilt 2000kms ago(Cleaned,Bored&honed and decked block/head)
CP Pitsons 8.5:1 with upgraded wrist pins
BC H-Beam Conrods
Regrund Crankshaft with ACL race Bearings
Tomei oil pump
Tomei headgasket
High octane 9L sump
New gaskets through out
New timing belt kit with water pump
Koyo 53mm Radiator
4 inch think front mount intercooler
Oil drain from cyl head to sump
Reconditioned head With BC SGL valve springs
Tomei Type B drop in cams
1000cc injectors
WALBRO 450LPH E85 IN-TANK FUEL PUMP
High Mount Precision 6262 Ball bearing turbo with full 3 inch exhaust (stainless catback)
Haltech platinum pro computer with Zeitronix wideband sensor kit
Rebuilt front diff and LSD rear diff
Bc coilovers front and back
All suspension bushes change front and back about 1.5years ago
Rear adjustable camber arms
Hicas has been removed with a lock bar in place
Front and rear Cusco strut braces
New Reco front driveshafts
Nismo twin plate coppermix clutch
DBA slotted rotors all round with reco calipers and braided brake lines
Very Rare Mines Centre gauges and Mines speedo
Blitz turbo timer , Greddy electronic boost controller and blitz temp gauge
Pionner flip out screen with Alpine amp , Alpine type R subwoofer and upgraded speakers
Air con works perfect
Carbon Fibre bonnet
Spoiler delete (Holes have been welded up)
Volk GT-C rims 18 inch with toyo tyres with about 40% wear(near new)
As you can see i have only used the best available parts, This car is very quick on the street and the all round performance of the R32 GTR is unbelievable for a car produced in the late 80's, If you have an enquires do not hesitate to send me a message or give me call
photos and contact details can be seen here :http://www.carsales.com.au/private/de ... -AD-2733379/?Cr=0&sdmvc=1
https://www.sau.com.au/forums/topic/442132-r32-gtr-for-sale-precision-6262/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
