Engine $6,800
Open to offers though
Speed sensor, pic please
Coolant reservoir cap? Ill only sell the lot together
Edited by Jezzza
Vspec II engine now $6,200 ono
Or take whats left of the car!
GTR body, some good panels. ALL glass
R34 GTR Vspec II engine, stock, unopened
Oilcatch can
Gearbox
Front diff
ORC 559 twin plate clutch
Nistune R32 GTR (R34 engine)
$8,300
Parts already removed..
Brakes and rotors
Suspension (drivers is stuffed)
Radiator
Shroud (gone)
clutch fan (gone)
Wipers
Front Reo (gone)
Brake ducts (gone)
Intercooler
All these parts with engine: $8,800
Edited by Jezzza
Price reduction and NEW parts!
New parts
- 3" min. cat back exhaust, one muffler and rear cannon, stainless steel, one dent in mid muffler - $200
- 3" cat with o2 sensor - $50
- RSR twin front pipes to suit RB26, 3" stainless steel - $300
- R32 Rear camber arms, unknown brand, look like white line - $150
- R32 GTR front diff - $400
- non-HICAS bar, unknown brand - $200
- R32 GTR OEM rear sway bar - $100
- R32 GTR OEM front sway bar - $100
- GTR fuel pump - $50
- GTR pump electronic senders and pickup - $100
Moving the BIG stuff, will be one of the last price drops as my shed is going up this month!
Wife wants to get it out of the house!.. so offer away!
- GTR bonnet - $300
- Passenger door trim - $30
- GTR Passenger seat with rail - $150
- Velo GP90 seat with rail (apparently S13) - $400
- GTR boot - $120
- GTR wing - $100
- GTR bumper with lights - $150
- GTR taillights - $40ea
- GTR rear wiper - $15
- GTR rear seats, top and bottom - $50
- GTR OEM front strut brace - $50
- Rear upper trim - $20ea
- Drivers elec switches - $50
- GTR 3 gauge cluster - $70
- Drivers door trim - $50
- Seatbelts - $40 the lot
- Rear boot lining + carpet - $30
- GTR AFM (one has broken tab) - $100 for both
- GTR headlights - $40ea
- ARC super induction box - $250
- GTR dash, and all associated trims - $70
- GTR wheel - $40
- GTR passenger mirror - $30
- Windshield cowel panel and rubber - $30
- Radiator silicone hose - $20
- Passenger elec window - $30
- Bilstein suspension, front drivers damaged - $150
If you require more pictures, please PM me with your number and part you are after
Cheers
Edited by Jezzza
Still have the N1 side pods avaliable!
These are not the rear pods, they are the ones that fit along with the side skirts
Genuine Nissan, one has two small cracks, very easy fix
$300
Hey mate,
I'm interested in dashboard along with main cluster, steering wheel, front and rear swaybars if new oem and maybe few other bits.
Can you send me some pics of the dashboard if its in a good nic as I have big bubbles and holes on mine.
Also your location and contact number willing to pick up tomorrow.
Thanks
Dave
PMs replied
Dash has small bubble passenger side above glovebox, I think pictures have it shown. Will get it out tonight/weekend
Main cluster = speedo? Its a Tomei unit, $350
I have the swaybars, OEM
Locations is Perth WA but can freight
**Refer to link in first post for parts available. If its not there anymore, it would be sold.
Some parts not yet pictured are GTR gearbox, twin plate ORC 559 clutch, front diff
I also have some misc. parts like A/C, P/W, swaybars, front suspension arms/hubs
Brake (ABS) master, cylinders, clutch cylinder
All glass available, rear is demister**
Edited by Jezzza
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
