Hey guys,
I was just wondering what are the stats on people getting pulled over for their white/hid headlights? I've been reading about how HIDs are not legal, to be legal they must auto level or self clean so I was just wondering the people getting pulled over for it in WA because most threads I've been reading are the guys over on eastern states. Thanks guys!
If you have projector headlights, they normally dont ping you for HID, even though it is illegal
But i have heard plenty of ppl getting pulled over/yellow sticker for HIDs on normal reflective headlights as the glare is unbearable
so xenon headlights on r34 are good to go?
nope
nope as in r34 xenon headlights are not projector headlights or nope as in they are illegal?
did my reading up on the Road Traffic (Vehicle Standards) Rules 2002 and it mentions
Part 8 Lights and reflectors Division I General Requirements for lights
s69 Prevention of Glare
"A light, except a high-beam headlight, fitted to a vehicle must be built and adjusted to provide necessary amount of light, without dazzling the driver of another vehicle approaching, or being approached by, the vehicle."
if i understood that correctly if it doesn't dazzle anyone it should be good? i mean the "adjusted" could just mean manually adjusted?
also in s75 Performance of Headlights
it just talks about how the light should be white, project its main beam ahead of vehicle and headlights must be fitted so their lights do not reflect of the vehicle into the driver's eye
Fact is you're all wrong. For HID headlights to be legal in W.A, they must be a factory sealed unit. All globes that you are fitting are illegal and you can be issued with a defect. I asked about them recently when passing my r34 over the pits.
So as long as the HID headlights are factory OEM headlights its okay? what do you mean by all globes that i'm fitting are illegal?
Nope they are not, they have to be changed over from xenon to normal ones when imported to meet Aus standards. The 4300k arent very annoying if you have them leveled right. I never had any problems with them for factory xenons even when i put 5000k globes in. aslong as you dont have a hid kit in there or replace the factory d2r globes with 6000k and over?
yeah sorry this is not correct, this is just a lazy answer from someone fobbing you off i think.
they ARE factory fit but dont comply with aust rules. which is why the ORIGIONAL globes are removed and retro fitted with halogen.
this is because they are not self leveling and self washing.
otherwise by that logic i should be able to keep or refit my factory xenon units.
you are correct that anything xenon fitted "ANYTHING XENON FITTED" to a skyline is illegal.
untill an engeneer gets your vehicle complied specifically with ADR this is the case.
i still run xenons, never given a thought to it, never been asked to remove them, still not fussed.
Edited by GH05T
Ditto - i still run xenons, never given a thought to it, never been asked to remove them, still not fussed
I think if the RTA failed you for this then they're just being kents
have heard compliance shops cutting wires and sticking standard globes in but that's a butchers job and can lead to issues down the track
  • 1 month later...
Bureaucracy wins over commonsense when you notice...
* dazzle from advertising LEDs by the side of the road at night
* dazzle from Chevvydores from in front or behind
* dazzle from high beams of grog-drinking, weed-smoking coke-hitting no-hopers after dark on Fri/Sat
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
