R32 gtr - 89 - 120,000km - Gun metal grey - 8.5k ono Stolen and recovered. (missing vin plate and compliance plate)
I bought this 32 GTR at auction last week with the intention of fixing her up but I've quickly lost interest and lack the motivation or time for this project.
One of those impulse buys .Like when you buy a gum membership.. haha
Spent about 30 mins trying to start it via the hot wired mess it came in, ignition barell is smashed and wires have been cut in the engine bay.
Can't get it started at this stage,
I don't actually know much about the car. from what I can see the mods are
Aluminium radiator
Purple coil overs
Cam gears
Damaged parts
ignition barrel
wiring harness
windscreen
compliance plate & vin plate have been stolen.
interior is in average condition, exterior is in fair-good condition
Car sold as is, will supply receipt as proof of purchase from the auction house.
Mark - 0438 416 584
https://www.sau.com.au/forums/topic/442743-r32-gtr-85k-vic/
If u got it from pickles auction then it will be stuffed eg wire cut on per-purse and under the car the hoses and pipes will be damaged from fork lift this car is not worth what u put the price on it ill buy it for around 3k 5k bing max
https://www.sau.com.au/forums/topic/442743-r32-gtr-85k-vic/#findComment-7276381
You went from 8.5k ono to 8.5k firm after telling us the wing got stolen?
Might go out and hit my car with a sledgehammer, increase its value a bit...
  • Like 5
https://www.sau.com.au/forums/topic/442743-r32-gtr-85k-vic/#findComment-7285064
Haha. I was replying to the question of what other damage was caused.
New Windscreen installed
New locks and barrel installed
Rear wing replaced
Import approval papers on the way from dotars.
Price hike 9.5k
https://www.sau.com.au/forums/topic/442743-r32-gtr-85k-vic/#findComment-7286893
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
