Hey guys,
A friend of mine is looking to buy an R32 GTR. We live in Perth but are planning on going down to Dunsborough over the weekend to check this one out:
http://www.gumtree.com.au/s-ad/dunsborough/cars-vans-utes/1993-nissan-r32-gtr-skyline-coupe/1041996076.
If anyone has seen this GTR before or knows anything about it, is it a good buy? The price is very fair given the work done to the car and the overall apparent condition of it. There will be a mechanic coming along to check it out too.
Cheers.
Edited by Uncustom
https://www.sau.com.au/forums/topic/443168-anyone-seen-this-r32-gtr/
Don't know the car...
Owner posted this about it on Jap Car Parts for sale WA:
The motor came from a wrecked 33gtr and it's done around 20k, it's only been in this car for 3000ks
The gtr had done a big end when we brought it
Other obvious things - white engine bay / silver car, non original dash. Above info doesn't quit fit? Could easily be explained or just me mis-interpreting it.
Goodluck
Well it wouldnt be the first or the last GTR to have a Nismo speedo fitted, most of them have. Quite when it was fitted is a question that you doubtless wont get an answer to. Doesnt have to be an issue just accept that it hasnt done 73kms. Fits into the same mystery bag as nearly every other GTR then.
If the motor compression is good (number read well) and is straight then why not atlest consider it?
Also it is not unknown for silver GTR's to come with different colour engine bays ex factory.
Also looks to have some Cusco (?) coilovers in it. Will be laggy with those cams.
Cheers guys, going to go have a look at it tomorrow. I'll let you guys know how it turns out. I have a 32 of my own and I know just how hard it is to find a decent example. Obviously it's going to be difficult to tell how hard of a life a car has had, even if it's presented well - You can only be so fussy with cars of this age lol.
Also about the engine bay colour, my 32 is silver and also has a different colour engine bay, slightly faded. It's normal as far as I'm aware :)
Edited by Uncustom
I've never known nor heard of R32 GTR's having a different engine bay colour to the cars external from factory. Especially not a silver GTR with a white engine bay.
All the R32 GTR's I have seen have a flat colour the same as the external colour. Silver GTR's have a flat grey engine bay.
:/ I could be proven wrong
Edit: That's not to say there is anything wrong with that GTR.
It looks tidy but you need to do a thorough check over.
Edited by Sinista32
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
