  • Replies 59
when are you expecting r33 rears.. i will probably grab one.
on another note, doesnt sound much like a group buy.. more like a business ad.
Please contact me about this.
Dave.
4-5 weeks...i can be contacted at [email protected] if you want to find me?
sorry i havent been replying to pm's regularly guys...there just too many atm HOWEVER i ALWAYS check my email and will endovour to get through as many pms as possible
basically there are currenly sold, more will be in abt 3 weeks
i will post when they are avalible.
cheers
greg
  • 4 weeks later...
Hey guys
Making/fitting rear braces for the r33 is not possible, due to its lack accessibility, UNLESS its GTR in which case it comes with a rear brace from the factory... :D
sorry... :D
My R33 (series I) had a Skyline branded rear brace already fitted when I bought it in May 2004.
But it is an active LSD model - GTS25t.M/LSD. Perhaps this model had a rear brace fitted as standard????? Anyone know????????
Whatever, it doesn't have front brace, and would like one of these.
Greg, any R33 front braces left?
They are back!
I expect Delivery to commence in early Speptember.
Strut Braces for:
SR Silvia/180sx FRONT (NO CA FRONTS SEE BELOW)
CA/SR Silvia/180sx REAR
S14 f & r
S15 f & r
R32 f & r
R33 front
z32 Front
JA80 Supra Front
Flat price is $85 for one, $150 for two.
This includes delivery to you door using Australia Post.
The price has risen slightly from last time, unfortunately this is due to a material cost increase and totally beyond my control.
COD and pick up are not available.
Other braces are NOT available, if and/or when they are i will post, please refrain from asking me if i can get them for your moms mini/lancer/prado etc, i dont mean to be rude but i simply dont have the time to respond to these sorts of emails .
Direct deposit is the only form of payment that is quick easy and simple unless you are in melbourne and wish to pay cash. This still requires postage as they are coming down from queensland, and they will be shipped to your door.
Please feel free to post all other questions and i will get back to you ASAP.
I will send my bank details via email, please feel free to post any other questions.
They are $85 for one, or $150for two including delivery Australia Wide!
For pics see: http://domainsheaven.com/forum/posting.php...e=editpost&p=17
(you will have to sign up, but its quick, easy and free!)
cheers
[email protected]
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
