You can feel free to make an offer FATZ whenever you like. For you ill do special price since half the car is your old 32GTR anyways :P
Ok guys so was also thinking would do swaps for parts with cash adjustment. Im looking for haltek ecu for my R33 series 2, high mount turbo setup including wastegate, exhaust and injectors. Pm if interested cheers.
  • 1 year later...
Merry Christmas all. Xmas bump! Car has been proven to run sweet around SMSP full GP track. Now with big WANG! And race numbers.
Price still a low $4000.
  • 1 month later...
Bump would consider swap for a road registered Stag or 4 door nissan/toyota. With cash also. had a few recent interests. Once again car can be picked up and tracked the same day. BYO fuel lol.
Now has 2 semi slicks to go with and spare rims.
