Hey guys just a couple of quick questions. Should I buy a back up computer for my stagea and get that done by nistune. I haven't delt with nistune before, how long do they usually take to install and get my ecu back to me. And finally once I have it installed how hard is it to sell my current ECU. Or does anyone have a nistuned ECU for an auto s2 c34 that they want to sell????? ;)
https://www.sau.com.au/forums/topic/443401-nistune-ecu-options/
Thanks for the info. I have checked out the nistune site and read every page 5 times hahaha. I just don't know all the little things like what sort of turn around time they have, how accurate the base image/tune is. What I am really trying to find out is should I buy another ECU send that to nistune, get all the other bits and pieces together then get it tuned. Or do I get the nistune done with base tune to the mods I already have then upgrade tune on dyno with a tuner. I was thinking about using Just Engine Management in ingleburn to do the final tune.
Nistune won't give you a base tune to suit your mods.
It will be exactly the same as stock once the Nistune board is installed.
Then the tuner can change the map to suit.
Nistune don't tune cars. They make and sell the hardware and software so cars can be tuned.
Thanks Ben, that is exactly what I needed to hear.
Currently only have pod filter, splitfire coils, 3" turbo back exhaust, radiator air deflector. As for the power goals I don't want too much more but was thinking hi flow turbo, nistune. If I have to maybe injectors and fuel pump if needed.
It is time to take a deep breath and work out what you really want from the car before making the next step.
If you are making the jump to modify then you will most likely need a FMIC, boost controller, Nistune, hiflow turbo or decent aftermarket, decent catalytic converter, fuel pump and bigger injectors.
If you are prepared to live with the stock turbo you can leave out the bigger injectors and possibly the fuel pump but I would still make sure the rest is done.
Take your time deciding because every time you change your mind it costs more money to R&R parts and then you need to pay to retune.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
