I have deposited $440 into your account for:
1x Oil Cap (Old Style) - $120
1x Low Temperature Thermostat - $110
1x GT Titanium Gearknob - $210
  • Replies 337
dave - will take a knapsack, pm me or email me - chris@(nospam)colorondemand.com.au,
remove the (nospam( bit :cheers: and I'll deposit the money
Regards, Chris
Lucien, I know that the old style is just an accessory thing you stick on the normal fuel filler cap.
Looking at the photo of the new one, it doesn't look like it's large enough to slip over the old one, so I would assume that it's a complete replacement... I could be wrong though, so don't quote me on that.
Both of the fuel caps are just covers that go over the original.
There is enough interest already, so will be placing order next week.. so get in now if your interested.
Can you get the NISMO engine and transmission mount kit?
Can you get the NISMO oil pan Baffle upgrade kit?
yes & yes... email if you want a price.
Dave
Could I get some info on how
how the low temp thermo works? (where does it go, is it hooked up to a light in dash?)
Also Dave I have sent you an email in regard to the clear winkers for the R33, they don't look like the ones I need.
JiVE - email sent.
Just to remind everybody... will be closing orders on 14th... so all payments need to be cleared etc by then.. so really if you want in you have to be organised by Monday.. only 4 days!
After that I will keep a progress update in this thread so everyone knows whats going on.
Dave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
