interesting!
will get the 1000s over the 1150 and save a hundred!
Ask the seller what pressure they are rated at though.
It's almost tempting to get three of each. I'm pretty confident they are the same!
1150cc flow at 4 BAR is the reply
4 bar = 58.0150951 pounds per square inch.
I stuffed up in previous post
Look at the chart again. At 4 bar the id1000 injectors flow 1150.
I would tell the guy to get f**ked personally.
interesting...
especially when they are $50 more for the "1150" ones... may see if i can get the $50 discount and just get the 1000ccs sent!
Now it's time to ask him what the 1000cc injectors flow at 4 bar.......
its a business seller on here.
i actually bought my 1000ccs from them that are still in my GTR today. there bosch and running fine.
Its not that i dont trust them, not at all. i just dont know the techincal side of things and im so confused!
Keep in mind also that the pressure that injectors are "rated" at is supposed to be the delta P across the injector, not the absolute fuel pressure. If you have 6 bar of fuel pressure but the pressure in your inlet manifold is 1.5 bar, then you only have 4.5 bar across the injector.
The Bosch injectors are not stainless internals, only the ID 1300 and Xspurt 1400's have stainless internals suitable to Ethanol/Methanol use.
I can beat his price on any of these injectors I imagine... ;)
all i am now is confused. have the bosch 1000ccs in my gtr from the same seller. running e85 and has done for a year or so now.. 389kws at the 4s....
god damn i wish i was smarter to keep up with this convo :P
I am running the 1000's too, had them in for 4 years on my daily. They work fine, but they are not rated to run e85, and would most likely fail if you ran Methanol through them. The e85 at the servo has an anti corrosion additive hence why they don't fail regularly.
If I was running a dedicated track car, I would either drain the fuel system after each track, or set it up properly using ethanol rated parts, such as teflon braided lines, poly tank, e85 Walbro's and Xspurt 1400's. Otherwise the standing fuel in the tank will absorb moisture between races, probably causing corrosion, injector damage or blockages. I have seen it many times...
this is the reply i got....
Hey,
I had a chat with the suppliers about this and seems they are in actual case same flow at 3 BAR, the unit's purchased do have a better spray pattern then the 1000cc injectors modified unit's hence the $30 price difference.
You are welcome to forward this onto the thread if you like ;)
Be rest assured I was only going off what the suppliers send me.
The 1000cc injectors are modified so that's why we have the same injectors in 3 possible options of 525cc, 750cc and 1000cc.
he fuel pump as well will flow even more then 460LPH at a higher pressure.
Both 1150cc and 1000cc injectors are E85 compatible most others are not.
I would not be trying to screw over a long term customer lol
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
