Bob you'll need to specify the model.
There's pre 91, post 91 and N1.
Ok....... I need both pre and post 91's for my ADM and V-Spec2.... N1 not so important.
I know the High beams are the same H3's and the Low beams are H3c and H1 respectively but I want to know the wattage.
Thanks,
Bob.
The 85W bulbs are std....... I had it checked out with Nissan yesterday.
I bought some "you-beaut" Phillips globes as the cars going back to Unigroup on Monday and I figured they can throw them in for me but..............
In the box of goodies I got from the previous owner there is a pair of H11 globes and a pair of HB3's..........
I'm hoping that it's just a coincidence (and error) that he gave them to me as I can't see anywhere our cars taking these globes.
A post "91 car should be H1's and H3's and these are for my V-Spec 2.
This is what I bought, I couldn't get The H1's in 85W bar Nissan and I wasn't going to pay $77.00 for a pair!
I could get 100W but it's risky putting more load on the wiring.
I got these 55W but with extra 60% coverage according to the box! How often do I use high beam....... Not often.
Hopefully they all fit.
Bob.
Bob did Nissan check the factory fitment in Japan or the upgrade as fitted to the Aus model?
The Aus model had 85W fitted as part of the changes to suit our "challenging" driving conditions.
I've only seen 55W in my 32's, even the N1 has moderate wattage of 60/55W in their H4 bulbs.
Hmmm...... Good point....... My parts guy knows I have 2 cars but may well of quoted based on the ADM.
Maybe the later cars got this upgrade too?
I'll know more tomorrow after they hopefully fit what I will give them.
I'll let you know.
Bob.
I probably should have just looked in the owners manual instead of digging bulbs out of suspect headlight assemblies !!!
Well...... That's our answer well done........ I think. What does the 2 and 4 mean on the top two lines?
Thanks,
Bob.
My handbook is for all model Skylines and I think sedans had a combination headlight which used the H4, thus only 2-headlights.
My car has individual low beam lights and high beam lights, thus 4-headlights.
I can't read Jap, so I'm just guessing.
The next light below (with the H3 12v/55W) would be for the fog light.
But Bob your question is doing my head in.
Handbook says H1 on high beam.
To my knowledge R32 projectors use either a H1 or a H3C on low, but they all use a H3 on high??
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
