So I bought a nismo fuel pump for my r34 gtt pretty straight forward installation as its a direct replacement pump. Put everything back together went to start the car and wait for it nothing. Can hear the pump priming but the engine isn't ticking over at all.
Any ideas? Nothing is leaking pump is priming so why isn't it starting?
Going to have another looking in the morning so hopefully i can work it out.
Thanks
yep 3 lines
1xcircle shaped line = black
1xelbow shaped line = orange
1xeblbow shaped line = yellow
joined them all back correctly
back to black
orange to orange
yellow to yellow
so can't see how that is wrong hmmmmm?
yep was running fine before this and yes all i did was the fuel pump. By not ticking over i mean it doesn't even attempt to start nothing.
I have a nistune but surly this wouldn't effect it to the point of the car not turning on
Did you prime the system lots before turning on? If some of the fuel has drained out of the injectors then they sometimes take a bit to get started. Key on and off a fair few times is the easiest way to do it. Key on, let it prime, key off, repeat
Also change your fuel filter in case the new pump has stirred up some crap thats got through the sock (not likely but id change the fuel filter anyway)
If the car won't start:
1) Check battery voltage, you need at least 10.5v while key on start (yes actually turn it to START, even though you think nothing is happening, what could actually be happening is there isn't enough voltage to bring the solenoid in to engage the starter)
2) check fuses
3) check start relay (30 needs power, 85 and 86 need to energize a coil, so a test light between them with the key on start should light it up)
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
    • FYI: Racebox RE7R Custom Tunes Released!   https://goracebox.com/.../2017-infiniti-q50-q60-re7r-tcm...   FOR GEN 2 (21+) VEHICLES, PLEASE SEE NOTE AT BOTTOM See more   But whomever tuned your car is the tuner you should go back to, AMS, Sonictune or BT Tune....
