  • Replies 82
So if the Stock GTR cams work in the RB20 could you use aftermarkets? Like HKS Step 1's? HKS web page with cam specs translated into egrish
R32,33 IN 264 degrees 8.7 110 degrees
EX 272 degrees 8.7 113 degrees
Rb20 IN 264 degrees 9.0 110 degrees
EX 264 degrees 9.0 115 degrees :)
        EX 264 degrees  9.0  115 degrees  ;)
i don't see why you couldn't? i think cams are generally for 'rb' engines so as to work in either rb20/25/26
just be wary that after a certain amount of lift, the rb20 head needs to be modified i think to accomodate the installation. can someone clarify this further?
The GTR cams are a mild upgrade that don't cost too much. Good bang for your buck. :cheers:
When you get into aftermarket cams the costs are substantially higher. Not just for cams themsleves, but valve springs, convert solid to hydraulic followers, machine head for lobe clearance etc. Suddenly it is not such good value as for the same money you can buy more effective upgrades.
Plus an RB20 is 2 litres and the larger cams you put in the more rev happy you needo be
The workshop where my car is claims the RB26 cams in Rb20 have been tried, and the result is ordinary... ie you lose power down low, and any top end increase seen with these cams isnt worth the trade off...not the expected result from a mild lift and duration increase. Also sighted concern over a solid lifter cam being used with hydraulic lifters.
So since they have my car, and they are advising against leaving the cams in, well im going to get them to take them out...for no other reason then if my engine dies after the tune, then i hadnt gone against their advice and they can be held more accountable.
Out of interest does anyone know if cams for sold lifter engines have a more aggressive cam lobe, whereby accelerating the valves open / closed any quicker then used for hydraulics...still having the same duration and total lift, but different gradient to fully open?
Can anyone verify that coz if i do the GTR cams I don't want to lose anymore down low power/torque :wassup:
Good point,can that be promblematic later down the track?
Well in my case I'm in the USA. Finding stock GTR cams is like looking for a Unicorn. If I do find them there won't be a big diffrence in price vs Aftermarkets :mad:. I have some stuff already just looking down the road.Pics of the stuff I have so far for the RB20 I'm not too worried about the lost of low end power, just a trade off you have to live with for topend.
BlueRB240 ... is that plenum for an RB20, looks neat!
Joel...are these figures right? The RB20 has 240deg - 7.8mm lift on both intake & exhaust , whilst the RB26 has 240deg - 8.5mm lift intake & 236deg - 8.2mm lift exhaust...is that right.
So yeh, the lift is really all thats really different between my R32 RB20DET cams and R33 GTR V-Spec cams. And even if the ramp rate was different, one would assume (i do a lot of that) that it becomes an issue as revs increase, not at idle or low revs (????)
Im over it now, ive only driven the car about 6 weeks this year, and it has cost me too much money (not alot compared to what most spend, but more then i lile spending)...just want to enjoy it again like i use to when it had the std turbo/injectors/ecu etc etc
Yer thats right, well according to tomei.
http://www.tomei-p.co.jp/_2003web-catalogu...haft-specs.html
Whats considered the Vspec N1? (as per the above link) ???
Maybe the higher ramp rate is causing problem with air velocity due to the RB20's slower piston speed?!?!? Theories.. :cheers:
What causes NA cars with big cams to have poor vacuum at idle...too much lift? Could it be a vacuum thing at idle...i dont know?
Camshaft overlap - when the duration is large and/or the centerlines are too close together.
Yer it is overlap.. Maybe the lack of piston speed in the RB20 (shorter stroke) isn't enough to create a decent air velocity hence fuel atomisation goes up the crap?!?!
Might start looking around to how ramp rate affects short stroke motors.
So any thoughts how these would work:
Tomei 256° / 8.50 inlet (PONCAM)
Tomei 260° / 8.50 exhaust (PONCAM)
on an RB20DET with a 420hp turbo...too big on the exhaust side, should i stick with 256 on inlet/exhaust.
Essentially if im not going to run GTR cams, i still want something to help beef up the mid-top end
as i own a R31 Rb20det ... cam duration being IN : 248deg and EX :240deg .. with 7.8mmlift
upgrading to the gtr IN : 240deg and EX : 236deg the 8.5mm lift .. will i actually gain anymore .. and is it possible to tune them with adjustable timing gears pacifically for more torque rather than top end power..
Well done to Waz on the successful setup ..sounds very promising for the other rb20 owners thats for sure
well when i had the GTR cams in (apart from not holding idle) when i drove the car it was super laggy down low, and didnt come on very hard at high rpm... which is what R31 power is describing. there were no other issues with my engine as when i re-fitted the std cams the car was back to perfect running order
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
