Hey
I've done searches in regards to this, but there are differing opinions and not many proper answers...
I've dumped oil plenty of times. This time though, after letting the oil drain for about an hour, I went ahead and put in fresh oil. But I've accidently overfilled...
It's 4L engine + .4L oil filter on a RB20DET. Engine has done 150k.
I put about 4L in, let it sit, had a look at the dipstick and it showed above H. Went for a small drive, let it sit again, but still sitting about 4mm too high. The dipstick shows the oil level about 4mm above max. and it just touches the letter H.
Should I drain some out?
Cheers
https://www.sau.com.au/forums/topic/443919-rb20det-oil-overfill/
Nah no dents, sump is all good. A fair bit of oil must have remained even after draining...
I think the best thing to do is simply get it at the correct level.
I'll see if I can drain some without undoing the plug completely, otherwise I'll dump the lot and then put it back in at the appropriate level.
Just to recap.
You come on here asking if the oil overfill is ok.
2 people say it is ok.
You somehow decide you should drain it.
Seems odd.
  • Like 1
Just to recap.
Seems odd.
I don't know why you'd say that, I get asked for help all the time and it goes roughly like this:
*phone rings*
Me: "Hello"?
Caller: "Hi I need your help with X, it's doing Y"
Me: "I know what the problem is, you need to do Z"
Caller: "I don't think so, I reckon it's.............."
every. single. time.
I think people are just f*cking useless at asking for help.
To weigh in on the original conversation I fill between the H and the hump on an oil change (in an RB25 you can just dump 5L in if you have drained it on a level surface). I assume the hump is the danger zone much like there's a hump on the low side as well.
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
