I have a shit load of plugs in my engine bay that have been chopped off at one end and aren't connected to anything.
The 2 shown bellow come out of the fuse box.
Has anyone got an idea of where the other end is meant to go.
Car runs fine by the way so they aren't anything major.
Oh
If you want to disable (like WILL NOT start but will crank).
Unplug and take the plug with you :thumbsup:
Unless your thief has one with them (so very unlikely)
tuck it under your fuse box
Edited by Sinista32
  • Like 1
Best anti theft device (short of them towing it or trailering it) is a simple switch in your fuel pump line. Just run it down near the drivers side kick panel and flick it off when you leave the car. Can crank it for days but will never get any fuel.
  • Like 1
Sweet, now we know how to steal your car :P
Go ahead! You I'll need to bring front crossmember, steering rack, tie rods, LCA's, knuckles, struts and wheels. Oh and a trailer to put it on. Probably won't be worth stealing though as the only thing it has in it ATM is a passenger seat! Haha :P
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
