400HP and 13ninety4: you may want to read a little harder. Defects issued for excessive noise from vehicle exhaust, Offensive volume from Car Stereos or starting/driving car with smoke/garbage being emitted from the exhaust carries a 3 point demerit.
Having said that, nobody I know who has been done recently for the exhausts have lost the points. This was a big deal a while back. Maybe they have changed the ruling however with dickheads like Michael Costa as the front runners in the "get rid of modified car hoons" posse, i cant see that happening.
My 2 cents
Croat: correct
99% of the time the police themselves have no exact knowledge of what is and isnt legal, they use their on discretion. Quite often a cop will defect for what they deem illegal but the RTA will clear it. If the engineers report is valid and you present it to the RTA to have it noted and listed on your registration, a cop cannot defect you for items on the engineers report, however anything not listed that they dont like, look out.
If a cop deliberately hammers you for something that is noted on the engineers report and you have done everything right, the solution is simple. Formal complaint.
Originally posted by croat
Hey BYBY how do you get engineering certificates? if you have them can a cop still defect you cause i heard if they want to be dickheads they can with or without a certificate... what can you get certificates for?
my old pulsar was engineered... different interior, 4 wheel DBA cross drilled brakes, engine conversion, intercooler, suspension, wheels, exhaust... it was all on there.. cops never got me because i always fronted with the certificate.
Oh, the insurer didn't ask for mods either, if you tell an insurance co that your mods are on an engineers certificate, they dont need to know the mods.
Christian
you can get everything engineered so long as the engineer deems them safe.
If you visit a workshop they can put you in touch with somebody (I know mark @ hills uses somebody - ph number in sig). otherwise you can look for an auto engineer and get them to do it.
Christian
croat you moron :D
you cant get illegal shit engineered hahahaha.
too loud is a defect, cant be enginnered. Deal with it.
bov is a defect, cant be engineered without huge and expensive adr and emissions tests. Deal with it.
too low is a defect, cant be engineered if its under the legal limit. Deal with it.
Now having said that, your car isnt that loud so shut up. You dont have a bov so shut up. and your car is no where near too low so shut up ahhahaha :D
By the way, apexi gauge comes in on tuesday bitch :(
Originally posted by XCUZME
croat you moron :P
Now having said that, your car isnt that loud so shut up. You dont have a bov so shut up. and your car is no where near too low so shut up ahhahaha :)
By the way, apexi gauge comes in on tuesday bitch :P
LOL!!!!!!
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
