Hey i was wondering what machining needs to be done to an RB25DET to fit GTR crank and rods? Is it a big job? Is it worth the hassle or would it be better to stick with standard crank, building motor to push out 400rwhp so would it be a benifit for my power level target?
https://www.sau.com.au/forums/topic/44435-gtr-crank-n-rods-into-gtst/
  • Replies 52
it would be a waste one would think to fit these to make such a small hp figure i reakon save for stronger pistons,linished rb26 rods and a set of cams cam gears etc this car would be a totally internally reliabe 400rwhp streeter SK your needed:) someone correct me if im wrong.
Hi all
Im new to this site and i was wondering what everyone would suggest, for me to be able to get around 300rwk from my gtst without changing the internals.
Current mods are full 3in exhaust, pod filter, adjustable tein suspension. Everything else is still stock as ive only had the car 3months. any sugestions would be appreciated thanx. These cars are the best :headspin:
so gtr rods will fit on the gtst crank? Sorry for the questions, as dumb as they may sound i honestly have no experience in this field and want to know alot b4 i build my motor, i dont want to build it and then find out that i could have used something else etc to get a better result.. thanx
Yep, RB26 rods are a cheap upgrade in an RB25 - rod length, journal size and gudgeon pin size are all the same. Rod width is a bit beefier, expecially around the big end journal.
300rwkw is pretty easy to get on a standard bottom end, there are a ton of posts on the forums of people who have done it.
No V.V.T. on the intake so you'll need to swap over to either RB26 cam gears or adjustables. Are you talking standard cams? If they are aftermarket you need to be careful of lift as they are made for solid followers, not hydraulic as the RB25s are... unless you convert them with a Tomei kit. Or RB26 valvetrain. Or make your own out of Coke cans. Or ask Alby Mangles for another way.
LOL (clown) :D
Im talking Standard cams, with adjustable gear.. I heard that this mode is done on the RB20's.. Not sure it would benifit a rb25
SK mite be abled to answer this Question
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
