Hey i was wondering what machining needs to be done to an RB25DET to fit GTR crank and rods? Is it a big job? Is it worth the hassle or would it be better to stick with standard crank, building motor to push out 400rwhp so would it be a benifit for my power level target?
https://www.sau.com.au/forums/topic/44435-gtr-crank-n-rods-into-gtst/
  • Replies 52
it would be a waste one would think to fit these to make such a small hp figure i reakon save for stronger pistons,linished rb26 rods and a set of cams cam gears etc this car would be a totally internally reliabe 400rwhp streeter SK your needed:) someone correct me if im wrong.
Hi all
Im new to this site and i was wondering what everyone would suggest, for me to be able to get around 300rwk from my gtst without changing the internals.
Current mods are full 3in exhaust, pod filter, adjustable tein suspension. Everything else is still stock as ive only had the car 3months. any sugestions would be appreciated thanx. These cars are the best :headspin:
so gtr rods will fit on the gtst crank? Sorry for the questions, as dumb as they may sound i honestly have no experience in this field and want to know alot b4 i build my motor, i dont want to build it and then find out that i could have used something else etc to get a better result.. thanx
Yep, RB26 rods are a cheap upgrade in an RB25 - rod length, journal size and gudgeon pin size are all the same. Rod width is a bit beefier, expecially around the big end journal.
300rwkw is pretty easy to get on a standard bottom end, there are a ton of posts on the forums of people who have done it.
No V.V.T. on the intake so you'll need to swap over to either RB26 cam gears or adjustables. Are you talking standard cams? If they are aftermarket you need to be careful of lift as they are made for solid followers, not hydraulic as the RB25s are... unless you convert them with a Tomei kit. Or RB26 valvetrain. Or make your own out of Coke cans. Or ask Alby Mangles for another way.
LOL (clown) :D
Im talking Standard cams, with adjustable gear.. I heard that this mode is done on the RB20's.. Not sure it would benifit a rb25
SK mite be abled to answer this Question
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
    • It always seems the uglier an animal is the more is costs
