Hello, I have a 1998 R34 coupe and im having some weird problems.
The other week i got in to drive it and when i unlocked it problems started,
1. The tacho and speedo dont work,
2. The bell chime for door didnt chime,
3. The interior light stays on,
4. The passenger door wont lock with the button on the remote or drivers side panel.
It still starts and drives fine,
I disconnected the battery and reset the ECU which worked, but then it happened again and again now that trick only works sometimes.
Any ideas? Cheers
https://www.sau.com.au/forums/topic/444407-r34-electrical-issues/
I reckon you should get it checked by an automotive electrician. Sounds like brittle cables between the battery and the accessories. Could also be a shorted PCB. I had a similar problem with my r34 in regards to the power windows, ended up being brittle wiring on the drivers side, causing the passenger side window to wind down but not up. Yours is a bit more complicated, i dont think its something that will just go away.
Any ideas? Cheers
Tacho + speedo: Take out the dash, check for lose plugs.
Interior light and bell chime for door could be linked (as i'm guessing with the switch on "DOOR" it stays on?, but "OFF" it turns off?) Guessing it is the switch inside the door playing up. Where that little rubber piece is.
Passenger door: Does it lock when you flick the door lock internally, like the actual switch? Does it unlock with the controls on the passenger door?
I was under the impression that its all just one big problem?
#@crissy
Did these arise all at the same time? Or did the car just start having more and more problems? If its the second question then id go with what sleptema suggested.
#@crissy
I don't think they can be related, or he would be having issues with the entire car, not just those 3-4 things. I believe the tacho and speedo gain their signals from the Engine computer, where the door lock and chime is body control computer. Tacho gets its feed from the CAS, which can in no way be related to the door locks. And if it was the ECU, I doubt the car would be running smoothly. I don't want to jump to ecu replacement when it is most likely small shit,
The ecu gets the speed signal from the speedo.
The tacho gets its signal from the ecu.
Weird hey.
And the ECU gets is signal from the CAS. The speedo gets its signal from the WSS yes, the ECU doesn't read the speedo, the gauge is an output from other sensors.
Sensor (input) -> ECU (processer) -> Actuator (output - in this case, gauge)
I'm saying the tacho and speedo are more than likely related, but the tacho/speedo combo isn't related to the door locks as they are on completely different circuits.
Edited by sleptema
Yes, the ECU gets it signal from the CAS, the ECU drives the Tacho.
The speedo gets it's signal from the gearbox output shaft, the same place as the ECU.
The wheel speed sensors are traced back to the ABS/Attessa ECU. The only time the ENGINE ECU references WSS is during traction loss (traction control for rear wheel drive only).
  • 2 months later...
Hey, Just wondering if you got anywhere with resolving this crissy? They are all connected in some way, as I have exactly the same issue. I have narrowed it down to the either the ODO/Speedo/Tacho cluster or one of the cables running into it, as generally by giving it a bit of hard tap or removing and reconnecting one of the cables from behind the cluster the issue goes away (until next time). It's funny when starting the car as you don't get the reverse beep or have the doors lock, and then all of a sudden everything happens at once, like a delayed reaction.
Edited by Phyco
Narrowed mine down to a contact issue on the TK20 Brown Connector (fuel gauge side) at the back of the cluster, as it has inputs/outputs for all the affected items (Door Locks, Reverse Chime, Speedo, Tacho, Engine Temp etc) just in case that is of any help to anyone else in future!
  • 7 years later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
