I'm having a very lumpy idle, way more than before, I thought it was the nistune, but i just got back from the tuning with new haltech ecu. Is it better ? Yes, but still lumpy.
I also made serious lost of power than 2 yr ago ( about 15% less), my tuner think it could be that my Poncam is missing a tooth. But to be honest, I'm unsure what it means and.. what can I do to correct it ? do i need to start thinking about buying a new set of cams ?
thanks!
It means your cam timing is out 1 tooth.
Take off the front cover, rotate the engine to top dead center, cam gear marks should line up with rear cover marks exactly.
If the gears are out 180 degrees, rotate the engine one more revolution, 1 crank rotation = 180 degrees of cam rotation.
If its wrong, your out X amount of teeth, you need to loosen the cam belt and reposition your cams the right way.
2cents worth
- Type B's sound lumpy.
- Dyno results vary allot
however, if you have slipped a tooth then get it fixed now
if your tuner thought it had slipped a tooth then he shouldn't let you drive away without warning you of the potential consequences
That's true.
But type b are hardly high lift or large overlap.
Exactly, I dont consider these camshafts too aggressive, not to mention, I'v ebeen runing these for 3 summers now. so I know how they should sound.. i just always thought it was my tune with nistune who wasnt good hence why i went with the haltech.
So basicly.. if it's off, it's not like I have to buy a new set of camshaft or go for a ''head'' rebuilt ?
Type bs are lumpy enough though if your used to stock idle anyway
2cents worth
I have great respect for my tuner but he is not a mechanic ( nor I am, I believe in '' if you don't know what to do, don't try and do it, but that doesnt means I don't have the right to understand whats going on with my car :) ) and i left the dyno at 2h am, so at this point we couldn't diagnotic the problem. The car run great with the new tune, it just that it don't make the low-end power i was used to and the top-end theres a lost of 75 whp, but mid-range sound ''about right'' compared to last year tune.
For what its worth, I have type B's and a haltech (on a rb28).
After a tune, I have idles which can be described as uh, REAL LUMPY. I mean, car-shakingly lumpy. In every instance it was actually due to it simply running very lean on idle (~17:1 AFR). I was able to add a little to get this to 14.7-15:1 and the lumpiness effectively disappeared.
If all that happened was you got your tune, it may simply be a bit lean at idle.
That's interesting to me, cheers
I run type B's and Haltech PnP on my 26 and it's also noticeably lumpier at idle
- thanks will ask my tuner next time :thumbsup:
I don't think we can compare a 25 to a 26 because of vct.
If you activate vct at idle the 25 will also be heaps lumpy.
Compression test came out to 145-150-155-160-160 so its OK and was rebuilt less than 15k kms.
My mechanic did the timing test and here's the result: Exhaust is spot on. However intake was a bit less than a teeth.. maybe 80% of a teeth. I was told.. if it would be off, BOTH cam should be, not just one.
whats your take on this ?
If the crank pulley was off then of course both cams would be off. But surely it's pretty obvious that only one cam could still have been one tooth out.
WTF is 80% of a tooth?
Why isn't he talking in degrees? Did he even use a degree wheel or just eyeball?
we used eyeball since we were in a driveway. while the exhaust was 100% spot on, the intake was a bit off.
Ok. I misunderstood when you said "mechanic did the timing test"
As the 100 percent correct way to check is with a degree wheel and dial indicator . I assumed that's what the mechanic did.
Are they adjustable gears?
yup tomei's one. I will be bringing the car at the shop next year but i wanted to do some backyard testing to have a ''feel'' of whats going on with my car.
Edited by cobrAA
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
