Hi guys,
Another group of parts, other post would have been too long.
A few more parts that I was planning to use but have gone another way with.
All items located in Brisbane.
Photos will be posted below the list.
1. R33 GTR Front Bar with Lip and N1 Slots
Comment: In good condition. The bar, lip and n1 slots are genuine plastic. The lip is in the best condition i've seen one in, has scrape marks and scratches etc. The bar unfortunately has had someone try to fit it on an R32 GTR ( X_X ). So the side mounting points have been cut a bit and also a hinge and bolt attached on the centre(Has caused a small crack). In the picture, there is one part of the bar that looks like has had plastic/silicon used and the bolted together. Considering the n1 slots and excellent condition front lip, i'm chasing:
Price: $600 ono - Postage i'm unsure on, happy to assist.
*Not willing to split unless I have buyers for each part or theres a generous offer from someone out there.
2. R33 GTR Airbox + Snorkel
Comment: In pretty good condition, most of it is intact there is one missing metal clip, but it holds together fine with the remainders.
No filter, cheap from autobarn/supercheap.
Price: $250 + Post
3. R33 GTS-T, GTS 3" Jasma approved catback
Comment: In pretty good condition, has been sitting outside for a bit, so may have scratches and marks from moving.
I am unsure if this will fit a R33 GTR, I was told R33 GTST. This is JASMA approved, so I believe is below the legal DB limit :)
Price: $450 + Post
4. R32 Nismo Lemans (?) Turbos -
Has 0.60 on Front and Not 0.42
Condition: 14411-06U00 is the part number on both. I have had these stored for a long time, never used them.
I'm not sure of the condition, a bit of shaft movement. Would probably safe to have them looked at/rebuilt. A/R .60 M24
Price: $400 + post
5. R32 GTR Standard Turbos, Actuators, Dump Pipes and Shields
Condition: One is in good condition with a bit of shaft movement. The other got damaged when a motor blew up. The rear wheel was damaged and removed. See pictures. Dump pipes and shields are as standard. (No manfiolds).
Price: $200 the lot + postage
Photos
If you need more photos, send me a message and i'll have it sorted.
6788F507-27C6-4643-86EC-E68E72A6933A.jpg6B6C3173-8903-44EE-AF65-A79682988941.jpg9500600D-E589-4C97-88C9-C301E5F07B1F.jpg70E4E76F-ADA0-4EB8-AD41-6A5B7BAA682A.jpgAC7BCF11-BB0A-45BF-ACEB-C339D886A4D3.jpgE169B5A1-47BB-472A-958D-45E125B9C955.jpg969B1164-A85C-4548-88D7-64E939EE2A28.jpg
2. R33 GTR Airbox
A71F100A-F4B2-4454-A8EA-2C9B98C83811-155
[img[http://i1239.photobucket.com/albums/ff506/owgasmz/71FFAF48-0762-46CD-9357-E2E8C34A4CE7-15554-0000174E9FB43FE2.jpg[/img]
4FD70F07-EFF3-40FB-99DF-DDA4008B8A78-155
3. R33 Jasma Exhaust
4CC04F8C-7B53-4162-83A1-6B59FDB25AD0.jpgFB5974D4-0365-4FE0-AECE-01AE273A0569.jpg49E32247-912B-4667-86A3-016F23337A8D.jpg838E52E6-AC0D-4D6F-B34F-0DF96B22C796.jpg
4. R32 Lemans Nismo? GTR Turbo
66DA52A5-A441-4BB8-A5FB-B5081E5E77A1-155
09C9C073-3B3C-4390-8784-34212930EAD4-155
A890E8A6-AFB1-4D83-A932-8983C17F699B-155
3DFB2781-CB26-494E-ADD2-6B7ABA57DC2D-155
882CEBD5-6391-443D-B0B3-BE51CCF57C9F-155
D1701C50-D6B7-4B0B-BF7A-C681B968E4A3-155
5. R32 GTR Turbos, Dump pipes and heatshields - (MANIFOLDS NOT INCLUDED)
B0E6C6A5-6E8E-485F-BD74-451EBCA069DD-155
9CF36D9D-12CB-4618-82D6-1933509401ED-155
3194967F-A866-405C-A5C7-FD210DEE8BE5-155
82718EC1-CC8B-4078-9AEC-8B62FFA1533E-155
2AB81C26-E81B-43C9-8833-9DF2986E04AA-155
E035F920-E0AD-42BA-9EA4-E99A9871B66C-155
Edited by Owgasm
5. R32 GTR Standard Turbos, Actuators, Dump Pipes and Shields - SOLD
0423 755 986 call me as soon as possible if u can sell me the lip on the front bar....
Will do George.
1. R33 GTR Front Bar with Lip and N1 Slots - $600
2. R33 GTR Airbox + Snorkel - $250 including delivery
3. R33 GTS-T, GTS 3" Jasma approved catback - $400
4. R32 Nismo Lemans (?) Turbos - Has 0.60 on Front and Not 0.42 - $350
Also have R33 GTR Injectors, with O-rings - 444cc yellow top
$225 delivered to your door express.
Edited by Owgasm
Are you sure the exhaust is 3"? I'm after something 3.45"
Not entirely sure, I will measure it tomorrow, I believe it is though.
Any reason for a 3.45" exhaust?
I didn't think much when I wrote 3.45 lol I was supposed to say 3.3/4" that's what I have now and I would like something the same size.
  • 4 weeks later...
4. R32 Nismo Lemans (?) Turbos - Has 0.60 on Front and Not 0.42 - SOLD
  • 3 weeks later...
BUMP
3. R33 GTS-T, GTS 3" Jasma approved catback - $350
SOLD
  • 1 month later...
Pics of bar?
Pictures in the first post. The first photos. If you can't see them, let me know and i'll PM them through.
  • 1 month later...
SOLD
  • 1 month later...
Also have a R34 GTR Airbox with Snorkel and K&N Filter.
$350 delivered
SOLD
2. R33 GTR Airbox + Snorkel - SOLD
  • 2 months later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
