Okay so im deciding what turbos to upgrade to and want to know everyones opinion.
Im wanting twin high mounts and want to get around 500kw or more..my motor is fully built and just needs a few extra goodies.
Im running greddy t517zs atm and its got over 300kw on low boost.
Im looking at getting a set of greddy t67-25gs as ive heard really good things but want everyones input so please feel free to voice your opinion guys.
Thanks
https://www.sau.com.au/forums/topic/444836-best-high-mount-turbos/
On petrol, or E85? What is "fully built"? Please elaborate on specs, and the rest of the setup etc? External gates? GTX2867Rs are the first thing that come to mind on the assumption you will be running E85.
^ As above..
Also need to understand what your car is used for and what you expect out of it in regards to drivability. As much as I love twins, for big power like 500kw I would lean towards a big single like a PTE6466 or EFR9180.
Whatever you do, stay away from the T67. That thing would be nearly 20-30 years old by now (technology wise)
Edited by Tonba
Sorry guys.. Motor has forged pistons, rods, big injectors, fuel rail, n1oil pump, nismo oil cooler, nismo intercooler.. Its on pump fuel ATM and plan to get cams, cam gears, e85 and a few other goodies.. I want 450-500kw and was thinking td06-20gs for it as i think running twin t67s will be too laggy as is purely for street use. If i run the td06-20gs.. I'm not sure as to run 8cm or 10cm??
Thanks
^ TBH, stay away from the Greddy / Trust turbos. They are laggy by todays standards.
Get yourself a pair of GTX2867R like Lithium suggested or a big single like a PTE6266, EFR8374, PTE6466 or even a EFR9180 (all in in twin scroll configuration for response)
Edited by Tonba
swings and roundabouts...
1. do you really want 500awkw? if so (unless it's going to be a hard parker with a dyno sheet in the windscreen)
2. start saving for a new gearbox
3. cash in the rego, throw in a seat, cage and buy a trailer (because unless your looking to get more cubes, it'll be essentially useless on the street)
4. start saving for all the supporting systems (I'll guarantee your fuel system wont support 500rwkw, clutch, cooler, oil and breathing mods, diff/susp/brakes, ign system, ecu/tune.... )
and the list goes on into a big spiraling dark hole of time/money and sacrifice/compromise
Cheers
J. :-)
You should get close with GTX28's shoved into -5 housings, twin Walbro 460L, possibly 1400cc ethanol/methanol injectors (or just put 2000's in there)
The rest can be done on a surprisingly stock engine bay, but be warned, the 26 block is very weak up around that power. I would be going for an unmolested 3L block and not boring it out much.
Nah, 26 block is no stronger or weaker than a 30 block, do what everyone does and do a partial grout fill for ridgitidy.
If anything the 26 block has oil squirters and the block grove for extra mains oiling already there, i wouldnt jump to a 30 block just for 500Kw.
Good Oil pump is a must in any RB build as is oil control mods.
You can get 400-450Kw with a set of low mount -5 and E85....
Edited by GTRPSI
Appreciate all your input guys..
I'm totally new to all this so i do appreciate all your feedback guys
To start with, be honest with yourself and really have a good think about what you want to get out of your gtr and how you would like to use it. Once you figure that out, you can start setting goals and planning mods/asking for advice for the best way to get the result your looking for.
Cheers
J.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
