It is with much peer pressure that I create this build thread. More to give everyone an opportunity to hassle me if I'm taking too long on certain items. I was reading a couple of threads just now and got really motivated to lock some things down and make a start on this sexyass car!
So here is is
1984 DR30
I imported this earlier in the year through Iron Chef imports after only a month of looking. It's clear that it's been sitting dormant for a seriously long period of time, but most importantly, the body is pretty straight (and fairly rust free (the fuel tank is a different story)) so I knew i could work with that no matter what happens.
It's fairly standard, except for the rs8's, front and rear strut braces, old school recaro's... that's all I can remember at this point. Between Feb and now i really haven't done anything except clean the injectors, oil change, change all filters etc and as far as doing much else, I really don't have the time or motivation to be doing these things so I've enlisted some help from some friends.
I bought it for track but still want to make it streetable, my last car I feel i went too far the track way and couldn't enjoy it on the street.
What's next? Here is a list of things that are getting done immediately (hopefully that will be finished by end of next week.)
- AFM is broken, have a new one on the way
- All fuel hoses are disintergrated so they are all getting replaced
- Petrol tank is getting cleaned out, resealed and probably relined
- Fuel float needs replacing
- New Walbro fuel pump will go on
I also have the following things on order or ready to go on.
- S13 hubs and knuckles so I can run the s13 coilovers, they have arrived.
- I bought this kit http://www.brysport.com/shop.html because using the s13 coilovers isn't without it's dramas... the back doesn't fit directly but this kid converts the two bolt strut top to three and also allows the car the standard amount of travel as the s13 coilover even at full extension does not allow for the standard DR30 height. Then up front, there is a tie rod end to dial out the bump steer issues. For the price and the issues involved, I'm pretty keen to try it out! It was designed by a forum member clubracer. Just waiting for him to finalise the package as it's a new product.
- MCA Red Series coilovers - I'm taking advantage of the group buy, just need to let them know what springs to use.
Once I have these three things delivered, a forum member will be working with me to set up the car properly as it's going to be a pig to handle and out of things that are not my forte, suspension is the worst of them!
https://www.sau.com.au/forums/topic/445479-dirty30/
Sorry kids!
I always was cooler than you, troy!
thanks guys! MCA have kindly agreed to reverse the fittings in the camber tops to they fit perfectly without losing the adjustability so I'm pretty stoked with that, the coilovers are base height adjustable too. I just need to send them a standard strut top thingymabob to do this
Now im just waiting for a replacement fuel tank.. my one was corroded so badly beyond repair!!! Couple more days I expect.
so once the suspension arrives, I can get down to work!
https://www.sau.com.au/forums/topic/445479-dirty30/#findComment-7346586
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
