Hi. there's this turbo for sale and before I purchase it I want to know if it's a dud. I know the only way to find out is to hook it up but if there's anything you see wrong with it please tell me !!
Description:
Selling the OP6 turbo off my R34Gtt and the alloy intake pipe due to upgrading. In good condition, crappy plastic wheel replaced and flowed, made 240Rwkw at 16psi
Apparent Reason for selling is that he upgraded to a gtt 3076
He told me there's "a little bit of float but no end play, blew no smoke". He also suggested to put another bush kit on it.
Can someone tell me what that means ? Any help would be GREATLY appreciated. Don't want this to be my second bad turbo I buy
https://www.sau.com.au/forums/topic/445555-should-i-buy-this-turbo/
Buy new or high flow your own is my advice.
I'm not real comfortable when one member asks the collective about another members FS either.
The responsibility is yours and cant be shared on others to comment on pictures unless there is something glaringly obvious.
Your going to have to look at it in person before handing cash over
If buying the turbo will have other consequences such as world peace or three wishes etc the answer is yes you should buy it.
If you like taking risks to maybe save money then yes buy it.
If you like to put on and take off turbos just to see if they are actually rooted then yes buy it.
  • Like 2
Sorry it may seem harsh and it's a hard way to learn. It's never nice.
If the turbo you bought was from a member on here then leave him poor feedback and post in his original FS the facts. "Bought this Turbo and it was shagged"
May not help you but will help others.
Save up and get your original OP6 high flowed and get rid of the worry. good for around 245kw's hassle free
There are other things you will need
Larger injectors
Fuel Pump
Nistune & tune
about $3500 all up including labour and highflow
or if you want new and cashed up go the 3076 and take it to around 300kws
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
