True Scotty but in this day an age (better computers/injectors/E85) I rather have an RB26 with a 9.5 static CR than the standard 8.5 . It wouldn't turn it into an RB30 but if the quench zones were done properly it should make more part throttle torque all else being mechanically equal - on E85 .
A .
Will increase lag.
High gas speed is where is't at... 1 inch runners, 6 into 2 before the flange so there is no open areas for the gas to slow down. etc.
Are you saying extrude honing increases lag or the stock manifolds increase lag?
Opening port diameters will slow down gas velocities, in effect giving slower than normal gas flow speeds.
Too small can also be a restriction, its a balance point.
Compressed air injection into the turbine wheel.
I'd really like to know if anyone has ever tested compressed air injection with simulated exhuast side pressures/gas flow?
... goes off to find my dive bottles.
Change to stock cams and stock diff gears, the more load you put on the motor the better the turbos respond, its why your car spools harder in 4th then 1st
It takes pressure to make pressure so the quicker you can pressurise the exhaust manifold the faster the turbo will spool
An electric super charger post turbo/s sounds like a good idea and fairly simple to manage under the guard before the intercooler
I reckon whats happening there is that a more fully opened throttle again a load that isn't allowing the engine speed to increase (high gear) means better cylinder filling so more heat energy to drive the turbine .
If you had your car on a hub dyno and could load it so it couldn't accelerate in any gear the result should be the same . Against a light load an engine accelerates easy with less throttle and not as much energy to the turbine so it accelerates more slowly - lower boost .
A .
Well, Disco......pretty much what you said, but more easily said as "load makes boost" and in lower gears you can't actually achieve quite as high a load at any given rpm as you can in higher gears. For the reasons that you gave above (ie in lower gears the car accelerates merrily away before it can achieve the loads you get in higher gears).
Edited by GTSBoy
To the OP. What particularly did you want to achieve. Is it off boost torque when daily driving, faster acceleration, are you falling off boost in between gear changes? What is it exactly.
The characteristics of a car is a sum of many parts not just the engine. So what do you want the car to be like?
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
