hey, ive currently got a rb20 32 with the following mods: front mount, 3" catback, pod filter, boost controller running 12psi on an rb25 turbo. im wanting to upgrade in the near future chasing 210kw+ while retaining good response with the following setup; hks 2530 or garrett gt2860, nistune, 440cc injectors, as for supporting mods thinking fuel pump, alloy radiator and hd clutch. am i missing anything/any extra suggestions?
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/
Bigger injectors and turbo will require an aftermarket ECU and some dyno time for the security of not blowing everything to bits.
I personally would look at a Haltech or similar also you'll need things like quality fittings on the fuel system and bigger fuel rail ect.
Also a bigger throttle body and a halfway decent intake plenum help.
Oil coolers are a must too since you live in aus.
I know its money but over engineering things for slightly higher than your aiming is never a bad thing.
Also a quality boost controller with individual boost profiles is good too.
I use a Greddy pro comp2 and have a low and high setting for regular driving/ rain and going fast.
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342641
never thought about oil coolers, i was going to get parts that directly replace the oem parts so i dont have to fiddle around getting everything fitted up. its my first turbo car so i dont know much about modding but what exactly does a bigger throttle body and intake plenum do?
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342648
There is no need, not now, not ever, to change the throttle body or the plenum on an RB20 even if you're chasing 50% more power than your target.
Your Nistune idea is fine - it will do the job perfectly.
An oil cooler is a good idea. Buy a quality kit brand new if you're going to do it. Not some cheapy linglong brand or secondhand.
Don't buy 440cc injectors. That number implies that you're thinking about GTR injectors. Waste of time and money. Just buy brand new Bosch EV14s of >700cc rating and be done with it. They will work fine even at your lower initial power level target and will also allow you to make more and/ore go to E85 if you feel the need. They will also be brand new, not busted arse 2nd hand shit.
Consider one of the Hypergear turbos instead of the ones you listed. A simple highflow of the RB20 turbo will more than adequately give what you're wanting, or he has a couple of brand new options also. Much much better value for money. Also not busted arse second hand shite.
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342656
Well I personally run a Greddy throttle body and a slightly larger intake on my RB20.
I did it for insurance as I run a Precision turbo PT5558.
I will however admit that I had professional assistance building my engine.
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342661
i was actually going to go for deatscwerks new injectors, they also have 550, 650, 800, 900 and 1200cc, my current injectors have played up on me already so i wasnt going to run the risk of getting 2nd hand, as for the turbo is there anything specific you know of that would work? i hit full boost with my current rb25 turbo at 3000rpm, i dont want anything laggier and quicker spool up would be better, dont mind forking out a bit extra for the turbo if its something good hence why i was thinking on one of the above (new)
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342666
I have similar mods but also a walbro 225 fuel pump wired in at 13.5 volts this increases fuel capacity slightly so I can run higher boost without leaning out on the standard injectors.i also have a mines ecu and I only run on premium 98..car goes very well and revs nicely to 8000.at the moment with my 3 degrees negative camber it wheel spins on boost in first and second gear.getting rid of the camber soon.they say ceramic turbo never boost past 13.5 but I been running 15 with no problems.maybe if you drifting may be another story also get a good afr wideband fuel mixture gauge.real important to monitor mixtures.on 15 psi I am running on full boost 11.1 which is safe.this tell me that my injectors are suppling enough fuel and im not running lean.apparently they say mines computers are shit,but I have not had a drama at all and ive had the car for 2 years as a daily.
I am in the process of installing the following mods..kinugawa td05 18g 8cm exhaust housing,nistune ecu,700cc injectors,z32 afm,,new recoed head,and tossing up whether to instal hks 264 9mm lift cam shafts....I don't drift it so I think this will be more than enough for the street.the rb20 is a awesome motor.i nearly bought a 32 gtr but I think as a daily the gtst is a better car.
you get dickheads on the forums just ignore them..they are like bored housewives.alot of the rb20 stuff links don't work.and there are a lot of awesome people with good advice...good luck
  • Like 1
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342668
i dont think ill push the current turbo past whats recommended (14psi max i think) because its my daily and i dont have a huge budget, would rather play it safe, i guess i'll do a bit more research on turbos, see if theres any other alternatives, i plan on getting gtr after im done having my fun with this car haha, nothing against the gtst and rb20's i love my car but i think a gtr would just have that bit of extra presence on the road
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342674
It isn't high boost that kills ceramic turbos. It's high shaft speed. Shaft speed is a function of flow (and boost, but never mind that for the moment). An RB25 turbo flows more than an RB20 turbo and so will make more boost at lower shaft speed when put on an RB20. Ergo, you CAN actually run at higher than "sensible" boost levels at the same level of risk as running "sensible" boost levels with the 20 turbo.
But there is still risk. These things can and do die at stock boost.
Go have a look at the Hypergear site. The RB20 offerings are clearly findable.
https://www.sau.com.au/forums/topic/445765-rb20-upgrade/#findComment-7342795
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
