fahod7 Posted July 19, 2014 Share Posted July 19, 2014 Hi I got skyline 99 GT2.5 Tiptronic it spent 160k problem is that while driving for 100 kmp/h, the gearbox should be on 4th. But some time it got to 3th !!! And the A\T Yalow light turn on I still can drive but the transmission will be on 3th What i always do when this happen is that i just stop beside the road and turn off the car for 5 sec then switch on then it work fine !! Any idea what is going on? Link to comment https://www.sau.com.au/forums/topic/445838-problem-with-the-gearbox/ Share on other sites More sharing options...
89CAL Posted July 21, 2014 Share Posted July 21, 2014 3rd* Are these 4 or 5 speed autos? I think they are 5? Does it ever go into 5th if so? Link to comment https://www.sau.com.au/forums/topic/445838-problem-with-the-gearbox/#findComment-7345971 Share on other sites More sharing options...
fahod7 Posted August 4, 2014 Author Share Posted August 4, 2014 (edited) not sure, i think the 5th not noticeable. But the thing is when i restart the car, it worked. I took it to do scan and says code : 1D Shift s/v A do not know what does that mean. Edited August 4, 2014 by fahod7 Link to comment https://www.sau.com.au/forums/topic/445838-problem-with-the-gearbox/#findComment-7357728 Share on other sites More sharing options...
Ben C34 Posted August 4, 2014 Share Posted August 4, 2014 That would likely be the shift solenoid (valve) A . Time to go to a specialist. (4 speed auto by the way) Link to comment https://www.sau.com.au/forums/topic/445838-problem-with-the-gearbox/#findComment-7357731 Share on other sites More sharing options...
fahod7 Posted August 4, 2014 Author Share Posted August 4, 2014 That would likely be the shift solenoid (valve) A . Time to go to a specialist. (4 speed auto by the way) so would shift solenoid (valve) A do this problem ? and how to test it. I just want to make sure. thanks Link to comment https://www.sau.com.au/forums/topic/445838-problem-with-the-gearbox/#findComment-7357759 Share on other sites More sharing options...
GTSBoy Posted August 4, 2014 Share Posted August 4, 2014 You test it by believing what the diagnostic told you and following the advice given to you to go visit an auto trans workshop. Link to comment https://www.sau.com.au/forums/topic/445838-problem-with-the-gearbox/#findComment-7357762 Share on other sites More sharing options...
Ben C34 Posted August 4, 2014 Share Posted August 4, 2014 (edited) As above How do you plan on fixing it if you don't know what it is? Typically when they stuff up it is an intermittent problem. So very hard to diagnose , except for the fact the computer is nice enough to yell you its problem. How about you ring an auto specialist and discuss with them. Edited August 4, 2014 by Ben C34 Link to comment https://www.sau.com.au/forums/topic/445838-problem-with-the-gearbox/#findComment-7357778 Share on other sites More sharing options...
fahod7 Posted August 4, 2014 Author Share Posted August 4, 2014 I did went to different workshops and both of them could not find the problem. i paid 1$140 for nothing they just gave me the code and they said we will replace the shift v for $300 with no grantee. ($300) for new solenoid only. in this case what im suppose to say ? I got a second gearbox for $300 and i think im gona buy it instead of fixing mine i have writing this threat to ask if anyone had this problem and what did you do to solve this. Link to comment https://www.sau.com.au/forums/topic/445838-problem-with-the-gearbox/#findComment-7357802 Share on other sites More sharing options...
GTSBoy Posted August 4, 2014 Share Posted August 4, 2014 Auto gearboxes are full of fairy dust and witches brew. Normal people do not work on them. AUTO TRANSMISSION SPECIALISTS WORK ON THEM. If you did not go to a proper automatic transmission workshop, then we suggest that you do so. Link to comment https://www.sau.com.au/forums/topic/445838-problem-with-the-gearbox/#findComment-7357849 Share on other sites More sharing options...
fahod7 Posted August 8, 2014 Author Share Posted August 8, 2014 Thanx guys for your commons. Most of the workshops told me that they will need to open and drop the gearbox oil and test the sensors. I will do that then will post Many thanks Link to comment https://www.sau.com.au/forums/topic/445838-problem-with-the-gearbox/#findComment-7361005 Share on other sites More sharing options...
