Didn't really want to make a new topic but seems although there's hardly any stuff on the hks3037s these days.. Thinking of putting one on my rb25 neo and just thinking will it be worth it in the end?
I ran the Garrett 3037 which is basically the same turbo as far as i know... Made good power, not too bad with lag etc...
The variables all depend on the supporting mods, the turbo is only one piece of the puzzle.
There are heaps of threads that cover this sort of topic!
Check the RB25 results thread if you need more info on setups!
Yeah, basically that. Given they are probably still sold with HKS tax I would probably look at one of the Hypergear boltons which seem to make similar power with similar lag and are as easy (or easier) to bolt on to the stock location - while being much cheaper.
Nice turbo, I love the old GT3076Rs but I guess it depends on what why you are specifically considering the HKS versus the good alternatives out there that weren't available when it came out
search = awesome.
http://www.skylinesaustralia.com/forums/topic/120893-full-turbo-kit-rb25/page-2
otherwise, have you driven a car with a GT30x series turbo on it? If not it is the main thing I would say you should do.
Of course we all want the most power but its the lag that is the defining thing on deciding a turbo for your needs.
After driving one on an RB25 (HKS3037 ProS- unknown specific model/trims) I found it to be too laggy for how I like a street car to behave.
Also I would go with a turbo now that is well suited to running E85 and set the response level I want on the turbo and then exploit the E85 fuel in making more power.
With Hypergear turbos, or even GT3071/6R, where they are at now and vs the HKS tax they just aren't worth it...
Edited by jjman
Agree with #@34GeeTeeTee in that the turbo is only one piece of the puzzle. And as #@Lithium said, it is a solid turbo, but IMO it might not be worth it with the 'HKS tax' these days...
You might be happier with a more modern turbo setup, such as a HTA3076R (look at #@34GeeTeeTee setup) or even a EFR7670 with internal gate (personally I would LOVE to see this turbo on a unopened RB25!!)
  • Like 1
The money side of things dont phase me as the turbo is second hand with very low kms. I've been considering highflows etc but I want to do it right the first time
ahh, so its not just a matter of turbo choice from the multitude out there but also the fact you have an option for buying a good and cheap 3037?
Again, have you been in the car it came off or in a car with this exact turbo on it?
As has been noted before, many people have ended up pulling bigger turbos off their RB because its just not much fun for the street and their driving style...
Yes I have been in many and 1. All I want is results/details on the hks3037...and makes it a lot easier as it's a bolt up situation. I know a garret 3037/3076 and highflows are a cheaper option etc. the car is a street/track option so I'm not overly fussed on lag etc atm.
At risk of disobeying the thread owner........This 3037 would want to be really cheap to be justifiable, wouldn't it? I mean, what you're looking at with one of these is an old school non-billet compressor and otherwise old tech in a secondhand package. For not much more than a grand you can get HG to make you a sweet billet bolt on, and for a bit more than that the FP/HTA stuff is also much closer to the leading edge of turbo tech (and probably not actually any better (read that as worth more) really than HGs stuff either).
agreed.
what is the ball park we are thinking of putting out there people?
full working condition good model HKS3037 pros with the HKS dump pipe and an intake pipe for $1000? any more is not worth it?
-the reason I am making it such a low price is that you are talking about a 2nd hand turbo. It is a risky proposition as you cannot tell what is has been through nor able to work out if it is indeed in good working order unless you take it to a turbo technician for a strip down and check...
Edited by jjman
In terms of results, a mate of mine got a .68 HKS 3037 tuned on the same dyno as I had my .82 GT3076R tuned on. On the same boost he made similar power with similar spool on the same boost, picked up slightly better down low and I made slightly more power. Basically in the dyno results thread you can ignore the HKS bit and look for GT3037 of GT3076R (not high flow, genuine Garrett T3 IW ones) and count those results as for the same turbo - the a/r will obviously just change the flow/response bias.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
