65991_10153271052699386_4120336822875212
And once again we have the SAU Vic monthly meet. Being held once more at 'Garage Cafe', Melbourne's best mixup of food and anything auto!
Come down on the 13th of August to say hello and have a chat to fellow members or even intro yourself if this is your first time as everyone is welcome to this event.
Bring your friends, family and yourself for a great social night with other car enthusiasts from 6pm onwards.
Everyone who comes on the night for the SAU Vic Monthly Meet will go into the draw for an SAU Vic Motorsport shirt in whatever size they might need,
so don't forget to get a ticket when you get there! Just look for the SAU Vic flag. :)
https://www.sau.com.au/forums/topic/446090-sau-vic-august-monthly-meet/
Will there be a motorsport update, lots of calendar TBCs or we going to have a separate night for that?
Not sure about updates at the monthly meet to do with the motorsport sorry. But there is the chance of a shirt! :P
Come on down tonight for meets, greets and the chance at winning an SAU Vic motorsport shirt! Look for the SAU Vic flag and come get a ticket for your chance to win! See you at the Garage Cafe from 6pm!
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
