Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
i'd say try a larger BOV that vents to atmosphere with a softer spring pressure....keep the airflow going in the one direction....feel sorry for you guys in Aussie with all your legal drama.
That will cause tune Issues with the afm though that will need addressing.
yeah but they'd be easier to fix. his mixtures will will be richer for a short time when he closed the throttle....could be sorted out whenever he wanted.
A dual stage BOV would be better, stage one plumb back stage two atmo, that way there is some air going back to AFM and some well not, the trick is tuning it to get the right amount
Well took off dipstick and can smell fuel big time. Will be taking off fuel pressure regulator vacuum hoses to look for fuel later. Stay tuned..this could be it, a leaking reg.
Thanks, is it better to get new though, never know when the used ones let go- will check if I can use 33 one on a 34- i think the 34 neo has 2 dampers n 1 reg
If a fuel reg is bad or fuel related problem on a skyline not holding pressure
There is the pulsation damper on the fuel rail to check
Turn it off and check how far the screw on the damper is sticking out and leave it overnight
Check if it has gone in and moved if so the fuel pressure is leaking if not all good
You were complaining about the fuel economy and the tuner has already told you the o2 is getting lazy
If a bad o2 was stuck too lean every time in closed loop it would try to dump fuel in to try to make the mixtures right
Check if your o2 signal is fluctuating when warm
Should be swinging high and low every second
Also with the intake I would try to modify the existing one as moving the afm further or closer to the turbo will affect the tune
And your std bov may not be flowing enough air for that turbo so it will still suffer from reversion and the std bov will leak
The only way a fuel reg can dump fuel in manifold is through the vac/boost line, start car and pull line off and look, for enough fuel to cause these problems it will flow out at you
I have personally never seen a factory fuel reg go like that
so is the standard BOV still considered adequate for these size turbo's, eg GT30/GT35..
Ive seen aftermarket ones and they come with a range of springs, eg 6psi , so if using that then boosting under 6psi would give a shhhzutututu which might be a way around the legal
side for people that want that, but you'd still have some reversion is that right?
On a stock rubber intake, the BOV return is quite close to the turbo inlet, so maybe modify the intake pipe to mimick that, so the entry point is close to the inlet and theres
a couple of turns before the AFM is connected.
Edited by AngryRB
I'm still using a stock bov with a 3076. I crushed it to apply more spring pressure so it doesn't leak.
Previously had reversion issues, modified return angle in inlet pipe and it fixed it.
Was surprising as the return was angled slightly to the turbo previously but obviously not enough.
It's a very simple thing to change, angled nd is very likely the cause of Ron ' s issues.
Anywhere that welds ally can do it. And cheap. And quickly.
  • Like 1
thats exactly what I will be doing tomorrow morning - check for fuel in the reg and damper vacuum hoses. Hopefully I will find fuel and confirm a dead reg - can i use R33 reg on 34 /possibly wolverine's one or do I need a R34 one - wreckers or buy new? Hopefully no touch up tuning required, but how to check if its providing the req. fuel pressure under load - else it will lean out n go bang haha..
I do remember when DVS Jez had a go at my 'stock' car 3 years ago he mentioned the fuel pressure's playing funny and advised me to get a spare r34 reg, which I got thanks to Johnny, so the second time round I went up to Jez with the spare reg, we didnt end up fitting it cos it was alrite then.. Now I have to look for that little reg, dunno where I put it or if it still there lol..
And yes I use a stock 'crushed' bov like Ben C34 does.
Edited by rondofj
^ lol that was soooooo long ago aye..
I have access to a hand held wideband, happy to spend a few hours diagnosing your car.. payment = beer :D
no worries mate will hit you up if need be, let me test a few other bits over a couple weekends - fuel reg, iron out boost leaks, earths, new O2 sensor etc; I have decided not to get the wideband cos of extra costs of equipment itself, weld bung away from turbine housing, touching up tune etc..
Do u guys get ur NGK O2 sensors from repco/autobarn/bursons etc?
I still prefer to change it and keep it enabled as it was tuned with it - do any of the R34 NEO people use the r33 NGK O2 sensors with the plugs cut off and wires crimped together? NGK dont make a R34 one, rang em up. Else the universal PEC O2 sensor from Vulture Motorsport is what I got and its gone funny after just 3 years!
Edited by rondofj
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
