even on a 20k loan @ about 11-12% the interest on a personal loan over about 3 years will be about $6k. Thats not too much when you average it out over that time into a weekly amount. And the difference between say 8% and 12% will only be a few $hundred in the end. Again, if the interest is too much then...
basically you'll struggle to get a "car" loan for an import
https://www.sau.com.au/forums/topic/44627-import-car-loan/#findComment-912060
you wont be able to a get car loan for an imported car OR "non delivered" australian car because the insurer will use the car as backing if you defunct and they dont like to use imports because they feel it will be harder to sell and you wont get any parts cos it was sold in australia.
Also another major reason is that the car wont be in the red book which is what racv, banks etc look for to obtain car depreciation figures and car resale values (its basically where market value figures come from). Import cars dont get put in to the "red book" so a bank cant estimate its market value
Personal loan you will be limited to about 20k max unless you have shitloads of money in the bank and some good backing for it (good assests)
https://www.sau.com.au/forums/topic/44627-import-car-loan/#findComment-912166
Most insurance companies now have The Red Book for Imports. It is widely available. I have had 29 cars mostley imports without a single hastle.
https://www.sau.com.au/forums/topic/44627-import-car-loan/#findComment-912470
Hey d00d.
Most places wont give you a car loan, I had the same problem, but if you apply for a personal loan you should get one. With a personal loan it doesnt really matter what your using the money for. I went with HSBC I didnt have any probs.
They will lend for than 20K for a personal loan.
Xtronic.
Hi,
I am after advice as to where to obtain a car loan to purchase an import. I have rung a few places but seem to either get knocked back or get hit with a massive interest rate does anyone know where to go?
Cheers
https://www.sau.com.au/forums/topic/44627-import-car-loan/#findComment-913225
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
