Hey guys, just notice spool imports sells spline driven billet oil pump gears to suit rb oil pumps.
http://www.spoolimports.com/billet-oil-pump-gears/nissan-rb/rb-spline-driven-billet-oil-pump-gears
Had a bit of a search but could find any account of anyone have installed or used them yet. Just looking to see what everyones opinion is on this option? In theory should be much more robust that the std 2 flat type drive I would think, however would there be any alignment issues or other issues that anyone has experienced or can think of?
Looking at possibly going down this route for a current rb30/25 build but would apreciate any advice anyone can offer.
https://www.sau.com.au/forums/topic/446380-spline-driven-oil-pump-gears/
I don't know why this wasn't done much sooner.
Company called supertec in UK/Europe also make them to suit different pumps.
Nitto is also coming out with a drive spline soon (they have been been doing R&D for a couple of years).
Did find that when searching but was a bit concerning that nitto has been doing r&d for so long and not yet released it yet. Makes me wonder if there is an underlying issue I have not considered?
Only thing I can think of is that it would require more accuracy for alignment/height of crank snout to oil pump drive centre. Would be less forgiving if it had to line up all splines?
If anyone has fitted a set with no issues would go a long way in making me feel more confident in going this option
I think I recall NITTO posting on here to the effect that the installed height of the crankshaft in the block is the issue. If you machine the main tunnels the crank can/will move up and down a tiny bit relative to the block. The oil pump doesn't. The flat drive arrangement allows some slack that lets this happen without problem. But the splines don't have that freedom.
Or something to that effect. Do a search - I'm sure there's something on here from NITTO about it.
Yeah seen that and thats what raises the question of issues with trying to install these spool gears. Would that be the only issue? So if im planning on using std main bolts and hence no line boring or altering of crank hieght (in theory anyway) should be all good?
In theory, communisim works.......
I dunno, I got alot of gear from Spool, and don't have any problems with the stuff. The rods look/are great and the rest of the stuff has been good. But I'd be more inclined to listen to pay attention to what the guys at Nitto are doing. With any luck spool have been doing the same research in the background, but I wouldnt want to be the guinea pig without any knowledge.
If it were me, I would call or email Spool and see if they have done some R&D into the potential issues with boring the crank tunnel etc. It's a good idea, Kinda wish I could have done this on mine, but then again I had to get the crank tunnel machined on mine so maybe not such a bad thing they werent around lol
As with any product R&D is the key to over come any initial design issues and potential problems. These gears we have supplied be it N1, OEM, etc have been tested in high powered street and track to ensure that they work as intended further more Tomei and Jun version have been used in 1000-1200bhp power RB26/30 engines where they are also hammering the limiter and revving up to 11k rpm.
The key to having a reliable setup is prior machining work to ensure that the collar is pressed on with the clearances provided and the correct temp requirements are met.
With our design there is ample clearance in the spline engagement to allow for any out of centre crank alignment with in the manufacturers recommended tolerance. Always best to get the main ends line bored if for what ever reason crank is not a lining up straight.
More pictures facebook.com/supertecracing
Edited by Supertec
  • Like 1
The issue with clearance is not exclusive to only Nissan OEM or N1, but the issue is some what masked with Tomei and Jun as they are thicker gears, but again using flat drive they are not immune from breaking the inner gear. One of our customers broke a Tomei inner gear. We have since supplied him a Tomei spine conversion kit.
  • 3 months later...
What are these spline conversion kits worth?
  • 3 months later...
  • 11 months later...
  • 3 years later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
