There are lessons to be learnt all the time working on cars.
One big tip is bunnings don't know or care about bolts. Go to a proper bolt shop for correct grade bolts and advice .
How rooted were the threads? I know that it's too late now, but a die nut would have likely cleaned them up. (Or a thread file, which works out cheaper and more flexible)
Hope you start having some better experiences in the future.
Agreed. Specialised bolt shop or nothing. Threads were pretty rooted but they are no longer an issue. I have replacements for them. Just got news that the bent shock has to be replaced and since its not a readily available brand it seems like the suspension place will be unable to fix it. Headaches....
Amir
Edited by Abdul11
Hey man, pretty sure we met on a track day at barbs. ( i think )
I have the bunky black bashed up 34 .
Just a suggestion, i have used the QFM track day pads a bit now and find they go to crap after 2 hard laps at barbs.
I would suggest going to EBC Yellow or Blue, or Project Mu.
I had EBC before and was alot better.
Im not exactly sure what causes it, but it most likely is related to heat.
And you having those ducts will certainly help.
They are not a bad pad, just once you go past there limit, dont expect to stay out on the track unless you rest them.
Alright. What brake fluid were you using? Also, did you notice they squeal a lot. I drove them around the street a bit after I bedded them in and they can squeal quite loudly at times. I will definitely try to set up the brake ducts as good as I can get them before going out this saturday. Are you doing the NL full day event?
I would, but i recently purchased a r34 shell i will be transplanting my running gear into.
So i will be out of action for a few weeks.
And im running high temp penrite "racing" fluid.
They do squeal first time i put them on, but after a while they are not to bad.
Edited by jay-rod
All the best with the transplant mate. Do you by any chance know anyonw who could fabricate a couple of brackets to which I can hook up the ducts. Im just using cable ties atm and they dont really work in getting the ducts to sit exactly where I want them to
Cable ties are your friend.
I have been using them for year son my skyline and they keep the brake ducts nicely in place.
I had to withdraw from Saturdays NL event but might pop my head up for a look. I am happy to have a look and make adjustments for you.
Track day at barbagallo yesterday - great fun. Other than my gear box (4th gear synchro clips) and suspension issues, the car ran very well. Managed to shave off some seconds off the lap times so I was happy. Good to meet Shaun and thanks for the tips mate. Also good to meet Andrew whos car is an absolute monster.
Thanks to the new rotors and pads I had on, stopping power was substanitially improved. I was able to brake much later than I was before which meant my right foot spent more time where it wanted to be - on the gas.
Only problem with track days is when the day ends. Now what? Looking forward fot the next event.
Will upload pictures of the track day if I find any of my mate.
Till the next episode folks....
Amir
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo :-D
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
