...to muffler delete, or not to muffler delete... that is the question...
I am considering deleting the rear muffler on my V35 Skyline Coupe and replacing the muffler with a custom Y-pipe, cutting the tips of the end of the factory muffler and having them welded back onto the end of the Y-pipe in the same position to retain a 'stock' and classy factory look (possibly spray paint piping blaaaaaaaack).
Who here has actually done this and what are your opinions on this affordable 'mod' ?
I'm not looking for performance gains, and I'm sure there won't be any... What I am curious though is if I would lose any low-mid torque from less back pressure? (Not sure how much this affects naturally aspirated cars)
Also, I am looking for an aggressive note... my V35 Skyline 350GT sounds brilliant all the way from 2k to WOT... so I can only imagine what it would sound like if we 'opened things up a bit' :)
Let the discussion begin!
The mid muffler is only a small resonator, it will sound hellish loud with the rear muffler removed.
I did similar on a Sirocco recently, running twin tips to the back, but I fitted a Varex mid muffler so he could quieten it down as needed. It worked great, still loud as fark though.
Mmm... I've heard no mention so far online of the exhaust being very loud without the rear muffler.... All the comments I've seen online have been that it's quiet during normal driving and a nice note with higher revs...
I definitely don't want it loud as fark... Just a much nicer note, that I can hear... compared to factory quiet.
As Ben said, just remove the rear muffler to try it. But, let me assure you, it will be loud as hell and sound like a giant awful fart when you accelerate.
There is a prettty good reason that all these companies sell HFCs, Y-pipes, mid-pipes and rear mufflers for hundreds/thousands of dollars - if it were as simple as removing parts to get a perfect sound, they would no longer be in business.
However, removing the mid muffler DOES give some extra sound and a tiny bit extra flow. If you are on a budget, I would suggest doing this first.
If I were to remove the mid muffler instead (at an exhaust workshop) could they just cut a straight pipe to replace it?
Simple job?
I did a fair bit of experimenting with sound on mine. It'll just be a slightly rumblier and louder version of the stock sound. If you've got the money, spend it on getting HFC's, then some custom piping to an aftermarket rear muffler like a Magnaflow, gives it a good note without being overpowering. In the end youtube is your friend, go searching for as many exhaust combinations as you can find, it'll give you a pretty good idea for what you want.
I'm sure this will be the same on the 35...but I have the 36 and I have a custom exhaust job done. I have HFC and an X-pipe muffler and rear muffler...the rest are just 2.25" pipes....It sound pretty damn nice after 2.5k....I can imagine if I had done 2.5"....itll be pretty damn loud.
Hey guys, what about replacing just the resonator with an aftermarket one that's affordable?
Any recommendations? Would it make much of a difference and be worth it?
After reading some feedback... I'm definately not wanting a 'raspy' exhaust note... due to straight pipes in place of deleting a muffler...
The videos I've seen on youtube of G37 sedans with a muffler delete don't sound all that loud... Is the v35 coupe a different muffler setup?
http://youtu.be/JVP13iVo3U4?t=7m55s
Edited by GFXman
https://www.fujitsubo.co.jp/english/legalis_r.html
This is the one I have and would definitely recommend. Like it says, only slightly louder, but definitely improved "note", with performance gains.
If you enjoy the comfort of your car, you will appreciate an exhaust that does not drone or make you involuntarily reach for the stereo volume knob when you are trying to be quiet.
Also, sounds even better again after installing a turbocharger.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
