Yeah it farts and just won't go. I can push it and it will climb but slowly and extremely rough. Just gave it a little push on the way home, sits on about 10.9 - 12afr when it starts shitting it self. Performance wise sell nice looms, but I am unsure of their quality.
I'm gonna block off the engine and do a 17psi charge on my isolated intake.
I really need advice as to where to go next. I just did another intake pressure test and I am confident there is no boost leak. I put a new set of plugs in and still no dice. The loom looks old but there isn't any damage to any cables. The AFM looks clean.
This could become an expensive procedure. I just don't know what to try and in what order. It could be CAS related. It could be AFM. It could be loom. All those components would cost me nearly $1000 to replace. Hell it could even be the ECU.
My car is modified, with an SS2 turbo, 740cc injectors, 040 pump, Power FC, Z32 AFM.
If I was to replace the coil loom, should I go second hand genuine, aftermarket or brand new?
Just did fuel filter. Grounded my 040 to increase flow. Cleaned the afm with maf cleaner and cleaned up the contacts on the afm and coils. No luck. I can make the car climb to 6 to 7krpm without boosting and its fine in the rom range. As soon as I push my foot down it blap blap and carries on.
So if im driving on light load the car is fine even at high rpm. As soon as I am on boost no good. If I boost up an incline its worse.
My tps is giving good numbers. My wideband is about 10 to 12 afr at wot during the miss. New loom for the coils next. If there is no luck then im taking it to a shop.
  • 3 weeks later...
Just got my car back from Unigroup. Running without any issues now. Coil packs were the problem. Has brand new splitfires in it now. Looks like old packs failed, new ones were duds. Had the car retuned too. Feels a whole lot nicer to drive overall. More power on same boost. Issue now is fuel system isn't sufficient to run anymore boost. Next mod is trying to trick up the power to the 040 otherwise I need a new pump!
I've made comments before about fake factory coils. Factory boxes, factory coils, part numbers stamped on boxes. I bought a set and sure enough, fake. Use Nengen or RHJ or Jessie Streeter. Good chance they will be genuine.
They must be fakes. The chap who I got them from was more than happy to support the product and offered a full refund but stated his parts are genuine and that he imports them from Japan from Hashim or how ever you spell it, who he suggest are the company who build coils for Nissan and Mitsubishi. He really knew his stuff when I spoke with him and vouched they are genuine. None the less he supports his product and was happy to help.
Hello splitfires, please don't let me down!
I have another question. Unigroup suggested my fuel system was peaking. They said my injectors are good for about 400kw and that the problem is either the fuel pump or the wiring to the fuel pump being insufficient.
What would you guys recommend as a drop in, no dicking around fuel pump? I currently use a Bosch 040 and this is the second Bosch 040 I've had go in this car. Ive also got a Nismo FPR. Could this be of any use to them to increase pressures in the fuel system? I need to find the DIY to beef up the power to the fuel pump.
If you increase pressure, the fuel pump will flow less fuel. As pressure rises, flow drops in a pump. The opposite to injectors.
Either run a pump that flows more or run a surge tank with a bigger feed pump(s).
I thought though that a 040 would be more than capable of flowing enough fuel for 260rwkw. I want to avoid a surge tank as the car is a daily and the smell of fuel in the back would be intolerable.
I can get a 044 and use the 040 as a lift pump and the 044 to feed the injectors but if i can get away without doing that I'd be happy.
So i take it the for wont do any good for me. If that is the case, what drop in is going go provide the greatest flow and life? I was looking at the nismo drop in. The other option would be a walbro 255 since these are proven oerformers. I want to try something new from the bosch pumps since 3 have failed on me in both my cars.
Edited by SargeRX8
Some say fuel lines tend to weep and since the boot in the bay isn't sealed the smell from weeping lines can get into the cabin. Ive got a small surge tank at home.ill get a 044 and wire up a surge tank and build a fail safe light on the lift pump
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
