spanner? you need a 1/4" socket set.. spanner will hit the fan and/or the ancillaries belts I think.. never tried loosening the CAS bolts with a spanner, curious now if it fits lol.. always have used a socket
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7366069
All done and didnt break the circlip. Im not a mechanics butthole but all went well and pretty straight forward. Ended up with 11-12lb boost heaps better to drive.
Next job is the new heater core i picked up. Not looking forward to that.
Then in 2 weeks going in for a tune. once i pick up the z32 ecu.
  • Like 1
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7372687
  • 1 month later...
Ok bit of progress and wondering where to go next. Got the ecu and nisstune and tuned and what a difference got 207 kw at the wheels which i thought was pretty good off a stock turbo, motor, injectors and fuel pump. Now what next to do. Im thinking afm, injectors and fuel pump. No idea on what type yet some research will have to happen
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398688
to be honest mate, you can't go much further without spending heaps and losing response anyway.
But if you want more power and I assume you do, next job would be new turbo. The stock turbo will die an early death if you push it any harder
supporting mods include but are not limited to:
-fuel pump Walbro GSS341/342 for petrol or F90000267 for E85
-Z32 AFM
-Injectors (if you want more than ~245rwkw on petrol or if you want E85 at all)
-coilpacks/clutch if need be.
Don't forget to run a direct battery feed for a new fuel pump regardless of which model you use.
Good luck
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398705
would i be able to reach 250kw with the stock turbo.
Absolutely not. Maybe on E85 you could get close, but it will be a bad thing to do. Turbo maxes out at less than this in terms of air flow, and when you push it that hard you are risking it flying to pieces (fragile ceramic turbine remember!!!!!!!!)
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398746
Cheers mate will probably go high flow turbo so boost comes on early unless there is an after market turbo that can do this and handle high teens off boost. Will get the fuel pump probably this week if i have time and then in a few months the rest and possible turbo
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398759
Look at http://www.sau.com.au/forums/topic/448435-factory-response-aftermarket-turbo-rb25/?view=findpost&p=7394103 to see what an HG highflow can do for you even with stock injectors. The ability to wind the boost up to values that will destroy the stocker is not to be scoffed at.
https://www.sau.com.au/forums/topic/446752-r33-s2/page/3/#findComment-7398771
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
