Ive been doing an rb25 into s13 conversion on and off for a while now. Im putting the harness in but I cant seem to find the air regulator plug. I know of the AAC plug (the purple one) but cant find the other one. Is it part of a separate harness?
https://www.sau.com.au/forums/topic/447089-cant-find-air-regulator-plug/
I think it will be PWM controlled by the ECU. The other plug that you dont have (which is brown in the photo I have, on the valve itself) goes to a solenoid so will need PWM to allow varying amounts of air through
Now there's a solenoid? :P lol damn
I cant take pics as the car is at my brothers work shop but googling around, the plug im missing is blue. The plug that goes into the AAC is purple (have that plugged in) and there is a brown plug I have nfi where it goes. Im guessing that's for the solenoid?
Stupid car....
My sister has a Series 2 R33 and is bone stock. I think im going to have a look at it and see what im missing. I think I have that solenoid in my parts bin somewhere...
Edited by Gameboy
The air reg is simply a 12V bi-metallic strip valve, nothing flash.
No ecu input, just power on when the IGN is on.
Doesn't even need 12V, engine bay heat will eventually shut the valve.
A pain to access on a 25, impossible on a 26.
I hate them.
Not to be confused with the purple plug idle bump up for the aircon.
Or the brown plug for the AAC.
Of course this is presuming the OP is talking about an R33 Rb25 and not a Neo.
I hate them.
Thanks for the post. Its a great help and yeah, its an r33 25.
Thanks guys, love this forum. :thumbsup:
Just as an added extra people used to power these cold start air valves off the fuel pump circuit say with a relay . The idea being that if the ignition was on for any length of time without the engine running the valve wouldn't be heating and closing up .
As mentioned most engines had these valves mounted somewhere where they got coolant heat early in the warm up phase so that if the power feed failed they'd still heat up and close .
How does the Neo system work .
A .
Although the air reg is IGN "ON" for power, it's actually all part of the fuel pump relay power feed which is controlled by the ecu.
So once the ecu times out the fuel pump, power to the air reg is also cut.
Attached is Rb26 system, 20 and 25 are similarly controlled.
Yes Cal, the brown plug (AAC) is ecu controlled, varying duty cycle signal.
Your purple plug is the idle bump up for air con, just an on/off solenoid not hard wire linked to the engine ecu.
Of course your aircon control unit (amplifier) does tell the engine ecu to control the compressor's magnetic clutch.
Found a photo of the Rb26 air reg, buried under the plenum.
They all look the same, 20, 25, 26, 30......horrible things.
  • Like 1
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
