  • 2 months later...
Hey guys,
Had a look through this thread the other night, i don't have an LM but it is good to see a register like this. I came across this on J-Spec imports this morning. I'm not sure how accurate there auction today cars are but I thought you might be interested.
Regards,
DW
  • 2 months later...
  • 1 month later...
  • 2 months later...
Hi everyone, have not been here for a while but currently running the Spool 2.8 Crank (1500bhp) with ACL Race bearings in with 2 new Greddy T67 Turbo Cores (550bhp each)...
its been a long time coming but hope to get it on the Dyno and see how things turnout!!
http://i21.servimg.com/u/f21/17/90/98/87/lm_gtr10.jpg
http://i21.servimg.com/u/f21/17/90/98/87/lm110.jpg
Thanks!
Here is an update on the spec list:
1996 Nissan Skyline R33 GTR Le-Mans Limited Edition.
Racing Blue 1 of 98 Made...
ENGINE Spec... 41,000km on the Clocks
2.8 HKS Stroker kit
Twin Trust T67 Turbos (New) Cores (550bhp each)
Cylinder head extensive ported & polished
N1 Bored out Block 87mm
Spool Bilited 1500bhp balanced Crank (New)
ATI Performance Super Harmonic Damper
ACL racing bearings (New)
Jun oil pump
Trust Big sump extension
Uprated Water Pump
HKS 2.0MM steel head gasket
HKS head bolt kit
HKS Intercooler 150mm
HKS hard pipes
HKS Elbows
HKS actuators
HKS iridium plugs
HKS 50mm external waste gate
Screamer pipe
Greddy plenum
Oil cooler filter relocation kit
SPEC-R custom breather/washer tank
Custom built exhaust system 4"
Pro alloy aluminium radiator
Tomei cam pulleys (New)
Greddy timing belt (New)
Clear cam cover
Greddy oil cap
Heat wrap
Turbo blankets
Greddy Air Diversion Plate
Engine plaque limited edition midnight club
Password JDM washers for engine bay purple
Could be more what i have missed out....
BRAKES & SUSPENSION...
Kawasaki Coilovers
K-sport 8 pot front Brake Kit 356mm with EBC Bluestuff Front Pads
DBA 4000 Vented rear brake disks (New) With standard Brembos
DRIVETRAIN...
HKS 6 Speed dog box
OS Giken Triple plate clutch (New)
Trust rear Diff 2 way
Quaife Heilix Front Diff (New)
FUEL SYSTEM...
HKS - Fuel Injectors 1000CC
Aeromotive fuel pressure regulator
Twin in tank Tomei fuel pumps
Greddy fuel rail
Aquamist water injection kit
INTERIOR...
Nismo 320KM-MPH White
Apexi Gauges White X6
Oil Temp
Oil Press
Water Temp
Boost
Ext. Temp
Fuel Press
Turbo smart 2 Boost controller
AEM Air/Fuel Gauge
momo steering wheel
Nismo gear knob
Nissan upgrade option, Momo Airbag/ Steering wheel, Nismo White Dials, Pioneer Carriozerra stereo and stacker and speakers
ECU...
HKS FCON V-PRO & Map Sensor
Road map done By Tweenierob (RIP)
WHEELS & TYRES...
Federal 595 RS-R Semi slicks (New)
Rota grids alloys
Rays Wheel Nuts Blue
Edited by torra
  • 2 months later...
  • 4 weeks later...
Anyone else seen this currently on carsales?
Is it one of the registered ones here?
http://carsales.mobi/cars/details/1996-Nissan-Skyline-GT-R-BCNR33/SSE-AD-3429307
This car came up again on Monday 4th Jan. It was listed from QLD, in the next suburb from me. http://www.carsales.com.au/private/details/_/SSE-AD-3429307
I called Tuesday, only to get a response car sold and already paid for (I suggested I could view the car within the hour,), and seller would not listen to any ideas about letting me view it anyway.
Same carsales advert number (#3429307).
Sounds interesting !
I have all the details. If anyone is interested in the photos/seller details from the add (including VIN plate) PM me.
  • Like 1
livewire (Kevin) - NSW - V-SPEC
KPCresta (Gavin) - WA Non V-SPEC
Pal (Eric) - WA - V-SPEC
32rulz (Ken) - Hong Kong - V-SPEC
smalls (Will) - UK Non V-SPEC
GTRLM1 (gtr.co.uk forum) - UK
ab20000 - UK - V-SPEC
torra (Jim) - South Shields, UK - Non V-SPEC
TheWatch (Marco) - Glauchau, Germany - Non V-SPEC
Bluzzer (Nicolai) - Denmark V-SPEC
Computer3001 (Stefan) - Freistadt, Austria V-SPEC
Ricky R33LM (Ricky) - Malmoe, Sweden - V-SPEC
Not registered yet (Dean) - UK
.R33. (Daniel) - QLD
updated list
Edited by Pal
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
