Out of curiousity, from the way that I understand it in QLD (and possibly the other states) it is illegal to view tv via an a/v display if the handbrake isn't on.
But is it still illegal to have the a/v display on if it is your only way of selecting songs etc (ie. one of those single din all in one units)?
Furthermore, what is the fine/points for such an offence?
Cheers guys!
-Alex
https://www.sau.com.au/forums/topic/44818-driving-with-an-av-display-on/
ive been pulled over twice. my tv is mounted in the centre of the r33 dash at the top, its blantly obvious where it is. i cant hide it or move it. cops checked twice, one sat in the drivers seat to make sure the clearance was ok and no problems at all
  • 1 year later...
What clearance? Ground or screen? :)
You can just install a switch inline with the handbrake wire so when the handbrake is on the TV is on, but when the handbrake is down the tv is off but you could flick the switch to turn it on. I know its not totally legal, but a small switch down the side of your centre console is not noticable at all, when you get pulled over etc.
i have a screen mounted infrount of the passenger and it has a switch on the dsh to turn on and off and i have had not problems with it since i got off my p's
My wife's car turns the video off when moving forward ie; speedo sensor input. The display still works for everything else (trip computer, sat nav etc) when moving forward. It doesn't turn off when reversing though, probably for a rear vision camera (if it had one).
This only applies to the screen the driver can see, the other screens (the ones the driver can't see) still work when moving.
:wub: cheers :wub:
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
