Hey guys, just wondering if its possible to unplug the o2 sensors without causing damage to find out whether car runs fine without them in use to find out whether they are the cause of a surging problem while cruising on flat road at 100-110 km/h and slightly rough idle for 30-60 seconds before coming good. Dont want to go replacing them if theres a way to diagnose whether its them playing up or not first.
Running factory ecu by the way
https://www.sau.com.au/forums/topic/448749-unplugging-o2-sensors-on-r33gtr/
Thanks guys. Changing spark plugs this afternoon so if that doesn't solve the hesitation/surging problem I'll try unplugging the o2 sensors and take it for a run to eliminate them or get confirmation i need a new set if it runs fine without them in use. Otherwise next step will be afm's.
Another question... If timing was changed slightly to suit power fc and then factory ecu was put back in, could that have anything to do with it? I've been told it shouldn't but Im not so sure
Well there you go. Youd think the place who tuned the power fc would have suggested that after i rang them when it started playing up asking if that could be the issue or if it needed to be done but said no it should be fine :-/ better find someone with a timing light then !
Changed spark plugs first with iridiums and started fine and idled fine while cold. I let it idle till it was warm as it was getting to nearly 2/3 on the temp gauge it started to idle rough like it was last time I drove it. Also changed the fuel filter and hasn't it don't its job since it was last changed. The black shit that was coming out of it was unreal so good thing I decided to change it anyway. After that the idle was still rough so figured i'de try unplugging the o2 sensors one at a time. unplugged rear one first and waited 10 seconds and no change. unplugged the front one waited about 5 seconds and low and behold the idle corrected itself and was purring like a kitten again, plugged it back in and after about 5 seconds.... idling rough.
Now I haven't yet been able to take it for a drive on the open road to see if the surging has gone away with the o2 sensor unplugged at between 100-110km/h where it was playing up before but fingers crossed once I put new o2 sensor in, it'll solve that issue too as it started at the same time the rougher idle did.
Thanks for everyones help and suggestions
AFAIK, the ECU ignores the O2 sensor(s) at idle and on a cold engine, so I am perplexed that unplugguing either of the sensors made any difference.
You may well have fouled the plugs by letting the engine simply idle to warm up. Engine runs rich when cold, best to drive it to warm up the engine faster. The fouled plugs, particularly if they are Iridiums, could well be a contributor to your idling problems.
The surging may well be the ATTESSA complaining about worn rear tyres.
Well it definitely did make a difference so I recommend others try the same if the same symptoms ever occur. I may try to get a video tomorrow to show the difference.
As for the plugs, if you read above, we actually only put the new plugs in today and the ones that we took out weren't fouled anyway but I just put the new ones in since I paid for the iridiums.
Never knew the attessa system complained about rear tyres lol. Im pretty sure there is still plenty of tread, it happened when just cruising on a flat, straight road at 100-110km/h at +/- 3000rpm so I doubt there would be any traction loss. Will take it for a drive tomorrow to see if it still does it.
the factory narrowband o2 sensors are used for idle and cruise conditions (light load) no factory tune car i've ever seen will foul plugs just from letting it idle to warm up. you are talking about water temp fuel correction....the ecu will input more fuel when the engine is cold.
Ok so just went for a good drive to sit on 100/110km/h for a fair while and low and behold, it drove better and smoother than its ever driven! No hesitation, surging at all and actually feels like it has more power and better acceleration which may have something to do with the filthy fuel filter we replaced lol.
  • Like 1
I had the same problem. It does affect the idle and definitely affects low rev cruise quality and mostly acceleration. By acceleration I mean backing off or cruise then move the accelerator and there is a flat spot or hesitation. Accel-enrichment does not help. Disconnected the O2 and drives just like a factory car. I have since changed all cells at light load and cruise to 14:1 AFR and run without a O2 sensor. It is better on fuel consumption at 420-430k to a tank and drives beautifully.
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
