Got it from a friend who bought it from autobacs japan years ago. Hand carried it on the plane home. Stored in for years forgot the specs.
I have attached some pictures to id it.
I mocked it up against a stock rb25det r33 turbo
-compressor housing looks same size
-exhaust wheel is bigger than rb25det turbo
-this garret turbo is oil cooled only
-has a 5 bolt internal wastegate plate (rb20/25 has 6 bolts) with 3 bolt to exhaust dump pipe
Compressor markings :
> A/R .60 Garrett M10 A.0. 2
>430753-7X
Exhaust Markings
> DH 3/4 Garrett M4
> A/R 63 or 67
Garrett Plate Markings
>14420-15P60
>444008-5
>SC 0125J
>Made in Japan
Is this a Journal bearing turbo or Ball bearing?
would also put this in a r32 rb20det engine.
https://www.sau.com.au/forums/topic/448803-id-this-garret-turbo-t3-flange/
Based on oil cooling only I will say it's a journal bearing.
And not worth much. Do you plan on using it? I wouldn't bother.
do u think this would make the same power as a rb25det (series 2 turbo nylon and ceramic wheel "45v2 21U") which is currently installed in my hcr32 rb20det.
also got 500cc high impedance injectors (ASNU serviced) and nistune waiting to be put in as well.
im thinking it will flow better because of the bigger exhaust wheel? and exhaust housing is slightly bigger than the stock r33 rb25det 45v2 21U turbo
I'd try to ditch this turbo and see if you can pickup a highflow. Dicking around with this turbo, making a custom dump flange etc. Pain in the ass. I'd prefer to spend a little more on the turbo for a bolt on setup and harness more power and better performance all round(response and general feel). Response is the real factor with these sleeve bearings vs ball bearing/bush bearing
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
