Hey all.
R34 GT-T gearbox with NPC carbotic single plate clutch. Was installed and running fine but engine died so it come out and is going on to the new engine. It looked in perfect condition when it came out.
So put it back in and now it will not disengage at all. Have bled/adjusted the pedal about 26 times now so I can confirm that it's not the issue. Pedal feel is excellent and I will attatch a video of clutch fork movement. Looking inside the box you can clearly see the release bearing pulling back the fingers of the pressure plate what looks like more than enough distance to disengage it.
As far as I am aware the only step you can gosh darn up in the install is putting the clutch itself in backwards? I didn't think it was possible but that's about the only thing I can think of.
Will having it in backwards make the clutch unable to be disengaged?
Any advice/help is appreciated. Thanks.
https://www.sau.com.au/forums/topic/449093-pull-type-clutch-wont-disengage/
Should also say that it was working perfectly with the R32 clutch master previously but won't disengage with the R33 master I now use. But by the look of these videos I'm 99% sure it's not master cylinder issue.
Okay so it's something internal. Moved the clutch fork until it hit the front of the hole cut out in the bell housing aka absolute full clutch fork travel. Still will not disengage the clutch.
What could go wrong with the pressure plate/clutch plate to cause it to still be engaged even though the release bearing is pulling on the diaphragm?
Nothing. Except for maybe it being in backwards.
Either way you aren't going to be able to fox it from the outside. Face the facts and whip the box out.
Edited by Ben C34
I know that Benny boy. Just asking if there is any known issues before I beak it open, find everything looks fine and put it all back together and have it not work.
I hope it is something as simple as clutch plate backwards but when I touch stuff it never is. Just got me stumped that it won't disengage even though the release carrier is doing it's job.
Box out.
Clutch looks good (definitely on the correct way, like I said, impossible to put single plate on backwards) pressure plate looks good, flywheel good, carrier bearing good.
Box in.
Exactly the same problem.
gosh darn.
Broken box?
Okay.
Clutch master is actuating the slave about an inch and has excellent pedal feel the entire way to the floor, so I would say that is fine.
Clutch slave has a decent amount of throw and no leaks etc, so I think that's fine.
Clutch fork is all good, not bent/cracked etc and the pivot point is all good.
Carrier bearing looked fine no abnormal marks etc.
Clutch disc itself looked fine.
Pressure plate looked fine although I wasn't sure exactly what I was looking for, just looking for general abnormalities. Also the carrier bearing is pulling on the pressure plate diaphragm and is pulling it out as it should.
So everything appears to be in a working condition.
When the car is on jackstands it can be started in any gear and the wheels turn freely and change speed with acceleration. This would indicate the part of the gearbox is fine Imagine (not sure what part as I'm no specialist). I also started the car in 1st gear and drove it around no issues.
When it was driving I was unable to get it out of first though, I was applying a decent amount of pressure on the shifter but it just didn't want to come out of first.
So yeah I have been thinking about it for the last 4 days and have not come up with a single idea that hasn't had a logical conclusion as to why it can't be that part that isn't functioning correctly.
Cash reward offered to the first person that tells me what the issue to my problem is.
"I also started the car in 1st gear and drove it around no issues." how did you do that with an engaged clutch?
Or is your problem actually "gearbox will not shift out of first" rather than "clutch will not disengage" ?
Spoke to Doug at NPC, the maker of my clutch. After I gave him all the information from the testing I have done he said the only thing it could be is a bent clutch plate. Da fark. How did that happen? Anyway.
He was kind enough to send me another one free of charge.
Put new clutch plate it and no change. Feels exactly the same as before. Can anyone recommend a gearbox place in Newcastle? I would rather slam my dick in a door for the next 48 hours than try and fix this piece of shit.
  • 1 year later...
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
