As per the topic i am considering buying this used hks gt-rs turbo for my s15. I have bought a few used turbos before but i just thought i would ask here for some more opinions, I am mostly concerned about the amount of corroision and the colour of the exhaust wheel and wastegate flap. Does it look like its had a hard life? I have the money to buy a new Gt2871R but this used turbo is less than half the price and i wouldnt mind saving the money if it looks ok.
Thanks guys
https://www.sau.com.au/forums/topic/449502-does-this-used-turbo-look-ok-to-buy/
Apparently the turbo has no shaft play and no marks on any of the compressor/exhaust wheel fins or inside the housings they run in.
I'm mostly concerned about the colour of the exhaust wheel and really and havent been able to find much info on it. The turbos ive bought in the past have had black sooty exhaust wheels. the only other turbo i have at home in one i changed on a saab because it had stopped spinning and the exhaust wheel on it looks a similar colour to this gt-rs
Im wondering if it was running to lean, or if it was on e85 or another type of fuel, there is very limited info from the seller as he bought a rebuilt sr20 and it came on it.
I would personally buy one new if you can't see it in person, heck I'll even throw in the Hypergear turbo idea... probably matched performance and new for a little more than that 2nd hand turbo... not to mention awesome support & warranty
buying a 2nd hand turbo is always a bit sketchy as it is super easy to clean any oil out of the comp housing to mask seal issues.
Buying one 2nd hand without seeing it in person is even more sketchy.
I'd suggest the hypergear line. Message Tao and tell him what power range you're looking for and he will tell you which turbo will do it with the best response. Easy; and as Johnny said it will have a warranty.
I'd be willing to bet it's not that much more expensive either
I believe the guy that there is no shaft play and have had luck buying used turbos before that are still running fine 10 years later. Anyway what is the hypergear equivalent to a 2871r 52t .64 or gt-rs. I know they are the same lets not do the Hks vs garrett debate on this turbo.
I don't see the point of going one size up with a 2860rs .64 aka disco potato .64. I don't want to change the cams from stock and want 230-250rwkw. I'm thinking upto 20 psi boost no more on 98 octane.
Stock turbo is fun and handy around town but I'm just bored with it really
mate be VERY careful about buying any second hand
I just went through the headache of buying "5000km old" GT SS turbos, looked fkn immacualte, mechanic inspected said fractional shaft play on one, oither was g2g.. once installed it was fked out and wouldnt boost properly when getting tuned.
Cost me an extra $5k for new turbos, stud kit, labour of the changover, tune and then the extra 2 and half hours of tuning already conducted on the old set (what should have been 6k for my job turned into 11) because a second hand turbo that seemd fine was bad
Not saying this will happen to you, but you need to ask yourself is the 1k ish saving worth the thousands of dollars of risk and the uncertainty of what your getting. Plus the GT2871 (or equivelant) will be a more powerful unit, so it depends if you want more room to move.
my 2c
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
