Every tune is different, and most tuners won't put the timing into an e85 tune, because the power is usually shooting up by that stage and they don't want to damage your engine. Why don't you speak to the guy doing the tune, as he would have a better idea of how hard he is willing to lean on it...
From my experience you are looking at around a 15-20% gain on ethanol, possibly more if the tuner is willing to lean on the timing. Doing so will cause exponentially high cylinder pressure, which can easily lift heads and crack blocks. If you want more power I would be simply leaning on the turbo harder before running more timing.
There is very little difference in response from my testing, but the midrange will certainly improve. All in all a great way of making extra power with more protection, by simply filling at a different pump, why wouldn't you run it...
Thanks Scotty
As I will probably hardly use the flex fuel set up I am putting on the car, but you never know. But in a few years my Son will.
I was just interested about E85. I understand it also runs cooler and blokes that use it seem to love all aspects, not just the extra power.
I think that's the point, there are so many good aspects to the fuel that most don't take into account. The 30% extra torque, the clean engine internals, clean exhaust and rear bar, plugs that never foul, less carcinogenic emissions causing lung conditions... Researching the fuel on here won't give you anything other than "more power is good" I would be google searching for other benefits, there are plenty.
I probably would use it if I could, but no E85 where I live but from time to time I will be able to fill up
I want to go to EC next year and it will give me a chance to use it.
Unfortunately that attitude is common from you NSW guys, which is why the rollout has stalled up there I think. They won't put more pumps in unless you use them, catch 22 I guess. I used to use a drum and pump at home, filling it with jerries. Where there's a will... :)
We have over 100 pumps down here now I believe, country servo's included. A lot aren't even listed on their websites.
Thats a truck load of benefits and it looks like you have done better for me than a Google search,haha
I did a search on where to get the E85 but nothing seems to be in the Mid North Coast, I will keep looking. Seems only Caltex and United sell it??
Cannot imagine driving 600Klms to fill a drum :(
I have a good idea, all you blokes pack your bags and come over the border :)
Oh and after we have all the pumps we need we will deport you blokes back to Mexico :)
Same tuner nothing changed except putting e85 in it.
Full boost was still the same rpm.
I dint know what gear jez runs on his dyno. Don't really see it mattering.
Like I said. Mid range was where all the gains were made. I really couldn't care about peak power. As long as it makes good power through the power band
Pretty sure Newcastle has a couple of pumps, not sure if there are more country NSW pumps around atm. United has a great app for finding them, but a lot of the newer pumps aren't listed.
If you tune on United you should have no issues running Caltex eflex, even without the sensor...
RBN1 and I have almost identical set ups except he runs -9s and I run -7s.
Power is very similar except for midrange. I'm on E85 and the torque coming onto boost is a lot more noticeable than on 98.
We drove each others cars a couple of weeks ago and I think that has convinced him to convert to ethanol.
The change that is shown on your dyno sheet might not seem like much but the way the car drives is well worth the change.
  • Like 1
totally agree :)
Thanks, I will ask around about Newcastle, sort of hoping there may be someone in Port Macquarie, if I get a few options I will certainly have a better chance of using it.
Going to check out United, I am think I did a while back when I got interested in putting the flex fuel sensor in.
I will talk to the tuner and ask him to do the United tune :thumbsup:
A conversion :thumbsup:
As for the dyno , my car was 338awkw and made a few changes and it only went to 345awkw , 7 kw BUT a totally different car to drive, even the OS Quad clutch became easy in peak hour.
We are talking about 400awkw ish on the Dyno with the 3.2 stroker build.So I can only imagine the difference 55awkw will make with the added torque/response.
Add E85 and ?? Plus the added benefits that Scotty mentioned, sounds like a no brainer using E85 just for the cars sake. I think there is another conversion :wub:
  • Like 1
That is about 6% , what gear? would be interesting if the psi was turned up a bit. Did you notice better low end response as well as mid range?
Kane are they different cams before the E85 graph? great result with the new cams :)
Wanted the comparison on the same motor same tuner if possible and would like to see what happens with lower and higher psi comparisons :)
nah this is after cams have been installed
hey dude just to give you an idea
you can see my setup in my signature but
317kw @ 20psi on 98
315kw @ 15psi on E85
388kw @ 20psi on E85
so you can see the difference. hope this helps OP
These figures here are after a full tune with cams. Same mods just a low boost and high boost on e85 and a high boost on 98
So there is your comparison
The benefit gain from E85 also depends on how knock limited your engine is, so if someone is very limited by knock then go to E85 they will gain more then someone that doesn't have any issues using 98 that just like the smell of E85 :D
The other thing I'm discovering ( from recent trackday where Amb was early 20s) with E85 is it doent like getting hot, where I never had any problems with 98, with E85 the engine will lean out and break down when the fuel gets hot and I m now looking into a fuel cooler
If you do really long drives and like to get up it or trackdays I would recommend a cooler if using E85
Be Interesting to see how effectivly the fuel cooler works Mick.. Where u going to put it?
I put I cooler in under the car once I realised the fuel was getting
Quite hot as the surge tank is in the boot with the pumps in the tank.
I didn't do a back to back but I might try get a infra red thermometer on either side of the cooler once it's up and running..
Obviously the car won't be moving so it will be hard to test unless I put a fan in front of it
I suppose a dyno will be an average way to test if the fuel is getting too hot by monitoring afrs
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
