Hey guys I just recently purchased a Nissan Skyline so why not join the forums!
I picked up a 1993 ECR33 Skyline 2 weeks ago off a elderly man for a price I couldn't refuse. The car had no roadworthy and was unregistered but I thought it was too good of a deal and I picked it up the next week!
It is
-1993
- 5 speed manual
- Rb25de
- Hicas equipped :/
The only modifications are a bad ass JVC 10 CD stacker and a JVC headunit with cassette player, and of course some "GENUINE" Bob Jane wheels with great tread.
Getting the car on the road was actually easier then I thought, got a unregoed permit from vicroads, took it to my mechanic, got my roady, went through the pits (which I was shitting myself over) and it was finally regoed after 5 days.
I have a question in regards to muffler. I recently picked up a HKS super drager and I want to put it on the car. It is only the diff back section and it is 3.5" piping (way to big for N/A) and 5" tip. Can a exhaust shop somehow sleeve it and chop it up to 2.5"? or could I just bolt it to the stock system and it would be okay? Cheers.
Pics for your time.The car has some paint imperfections but at this stage im not bothered.
Cheers :)
needs a good clean!
https://www.sau.com.au/forums/topic/449792-first-post-picked-up-a-na-r33/
Thanks mate! Yeah its great car to drive! Well tomorrow morning im taking the car in to see what the exhaust shop says.
But yeah never know it might okay since its only diff back and hopefully wont make the car sluggish, seen a few people here saying they run 3.5" from cat back on N/a lol.
So bad news.. no exhaust shop wants to touch it as 3.5 inch inlet is just too big :( im now going in the direction of custom instead
Not so bad. Nice looking car - put your money towards better brakes and suspension instead.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
