Hi I was looking at my rb25det block and I tried to take a measurement on it any way my micrometer is is to big to measure the oil restrictors. So my question is I am trying to find out if these oil restrictors are stock or after market I came up to a number that seems to small to be stock, the measurement is around .055 which is about 1.40mm so I am not sure if these are stock or not. The number I came up with is probably off as I can not get a accurate measurement.
Thanks
Richard
https://www.sau.com.au/forums/topic/449929-rb25det-oil-restrictors/
I have read the oil control thread but blocking one feed and restricting the other does not sound like a good idea to me as I am running the car as a street car and hydraulic lifters. People say well the rb26dett has smaller restrictors and one oil hole blocked off but the 26 had solid lifter and not hydraulic lifters like the series 1 and 2 rb25det which means the lifters need a lot of oil. I am thinking of running a line from head to sump but not sure about the restrictors or blocking off a oil hole.
Hi Ben C34 I was using a vernier calipers.
Thanks
Richard
Can't believe you're still thinking of running a line from the head to the sump after reading the thread.
Don't forget vct supplies some oil to the top but if you are not keen on blocking off one of the oil supplies you can do what I did - fit 2 x 1.0mm restrictors.
  • Like 1
Hi KiwiRS4T do you have hydraulic lifters, BTW I like your idea on running 2 x 1.0mm restrictors, so do I put the 1.0mm restrictors in the middle and rear oil feeds. BTW when I looked at the restrictors on the tomei website it says do not use restrictors in conjunction with the hydraulic lifters which seems not to be correct.
Thanks
Thanks
Front and rear leave the VCT alone. What kind of oil pump are you using? What are you using the car for - track only? Street car? Circuit track days?
Actually mines on an RB30 block with an RB25DET head with hydraulic lifters and an external supply to the VCT.
Never mind Tomei get the restrictors from me!
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
